Vectra 1.8 petrol 1997 (again)
Started by rikki_essex, 03 May 2013, 08:11:46
rikki_essex
Morning all sorry to be a pain with this car but i seem to have a problem and thought its best to ask on here. On my trip into work about 3-4 miles into the journey the car jerks throws up the eml then runs fine with the light on although i cannot go over 4500rpm ive been looking around and found this
http://www.vauxhallownersnetwork.co.uk/index.php?threads/engine-management-ecu-problem-ridiculous-price-from-vauxhall-to-replace.238831/
I hope its ok to post this link from another forum if not please remove it.
I have done a paperclip test and the only code to comeback 0335 (crank sensor) but apparently you will always get that if the car if off. The post above points to cam sensor do you agree?
regards Rik
Wish i could answer that rikki , wonder if it mite be the lambda sensor playing up  :-\
omegod
Cam sensor on my old 2.2 mig would pop in and out of limp home mode randomly, codes were coming up for random things like the auto transmission, crank sensor until I left the scanner attached while drivibg and scanned it straight away as soon as it lit up, nailed it as the cam sensor being at fault. New one fixed it ! 52 quid on trade at the time I think.
May not be your issue though  :-\
SIR Philbutt
Use to have a Vectra company car (around 1995). Started throwing up spanner light and limp mode, mainly from cold. Off/on ran ok.
Booked into local stealers, new cam sensor. Few months later started doing it again, new cam sensor. Then again a few months later.
Spoke to leasing company and got them to recommend another stealers. They apparently contacted them and asked for genuine parts to be used. Problem solved. There endeth .......
HTH
Phil
dazzerM
My 1.6 Zafira has had the lambda sensor fault code for 2 years now, Eml been on since Summer 2011 and never has it gone into limp mode  ???
If it were me I may be inclined to get it plugged in somewhere that knows what they are doing, alternatively you could end up replacing a cam sensor and Lambda at a cost of 80 odd quid and it may be neither  :y
Darren
Jukeboxnut
My wife's 1.8 petrol Vectra estate did the same thing about 5 years ago.  I replaced the cam sensor and it has been fine ever since.
henryd
Quote from: dazzerM on 03 May 2013, 19:16:54
Yours zafira code is probably for the heater circuit and it won't go into limp for that :y
other rides
dazzerM
Quote from: henryd on 03 May 2013, 21:04:56
I'll have to check it again, there's you putting doubt in my mind now  ;D :y
Darren
dazzerM
Henryd bang on the money, just plugged it into my newly acquired Auditel MS509 and yep.... Heater circuit fault current  :y
Darren
