Best source for DIS pack?
Started by tunnie, 04 May 2013, 09:37:28
Won't know for sure until tomorrow that MotherT's 3.0 needs a new DIS, but when I do order one whats the best source these days?
Its the vertically mounted kind, with I think the oval plug (2000 W 3.0)
Seen some eBay sources, or worth paying a little more?  :-\
symes
not sure but if vertical type then plug is square-pity you not local-got one here mate from 2.5--bosch
Sure the plug was Oval, did not see it that well removed it by feel.  :-\
Whatever you buy, if you don't seal the scuttle properly it won't last long!  :(
Quote from: TiggerHayes on 04 May 2013, 12:43:50
Noted, current one is visually in perfect condition. I think the failed HT lead has caused a fault  :-\
Quote from: tunnie on 04 May 2013, 12:45:07
Quite likely :(
The HT will take the easiest route to make a circuit. Usually the circuit is down one plug lead, over the spark plug gap in the cylinder about to fire (big voltage drop here), through the engine block, across the spark plug gap in the cylinder on the exhaust stroke (small voltage drop here because the hot exhaust gases readily give up charged ions to carry the charge across), then back up the other plug lead to the other end of the coil.
If the normal route isn't available then the voltage will rise as high as necessary to punch through a new route - possibly straight through the insulation inside the coil.  :'(
I don't mind it being the DIS pack, straight forward fix  :)
Radar
Vauxhall world parts - i got gen. bosch last year at good price - they sometimes have discount codes going on.
Quick favor to ask is: GM Part: 90541062
Correct for DIS on MotherT's 2000 3.0?
Looks right, plug is in correct place and shape...
I bought a pattern DISpack about 15 months ago and it worked fine. I'm not sure if it was the same supplier but it was one like it and the price was about the same.  :)
However she's misfiring again, but that's not to say the DISpack has failed.  I havn't had a chance to investigate yet...  :-\
Is a known good one from an OOF breaker or Steve at Omegaspareparts not a viable option Mark? :-\
Bought one from Vauxhall World Parts on next day delivery  :y
If mine's gone again, the next one I fit will have a good coat of grease and will be wrapped in clingfilm....  :D
