Ford Sierra Radiator
Started by Steve Brookman, 04 May 2013, 11:16:19
Steve Brookman
Morning all,
Still having slight issues with my Sierra. Started getting hot a bout 8 months ago-replaced water pump, thermostat and foolishly (I think) the HG. On the level the car is fine but when you come to a hill the temp starts to rise-it doesn't overheat but climbs rapidly towrds the Red.
I'm now suspecting a partially blocked radiator-I tried flushing a few months back and it did make a slight difference. The radiator is original and 20 years old.
Any ideas greatly appreciated./
Steve
Previous
Omega 2.5 GLS Auto Estate         S115 JVV
Omega 3.0 Elite  Auto Estate        T639 TFA
ozzycat
could be the radiator try the holts 2 part flush its worked for me but somr peeps on here may have a better solution
long live the magic tree
its good to be back
symes
take radiator out and stick hose in it and flush it through while rad is placed side ways/upside down -works on rover p6 rads :y
you can blank other outlet on rad with plastic bag/hose clip if required
Steve Brookman
Thanks,
Tried the 2 part flush-will take it out.
The radiator on my P6 was very easy to take out if I remember!
Wish I still had it (P6 3500S).
Thanks
Steve
Previous
symes
Quote from: Steve Brookman on 04 May 2013, 11:51:26
Thanks,
Thanks
Steve
mine is 1965 2000 with buick 300 in its nose ;)-am doing fron lower ball joint later today :'( right pain to do >:(
sassanach
just stick your mitt on the rad when the engine is hot,it should be warm at the bottom and stinking hot at the top.you will NEVER successfully flush a parallel flow rad that has furred up inside.water gives up its limescale at approx 60c, engines run at approx 95c.
biggriffin
Go to plumcentre/screwfix and get some fernox flush. Top stuff. :y
Hoof'land storeman.
martin42
to be fair using a fernox etc could make matters worse,personally if it is orginal,get it refurbed or replacement,will be quickest and easiest option  :y
Steve Brookman
Thanks all,
Will get a new one.
Cheers
Steve
Previous
0795omega
are you sure it is actually getting hot,i had a 1990 2.0 pinto sapphire thats guage would sore into red,it was a faulty guage in the end nothing wrong with engine!
Taxi_Driver
Quote from: biggriffin on 04 May 2013, 13:17:33
Some of that stuff eats aluminium as well as limescale  ;)
Taxi_Driver
Quote from: sassanach on 04 May 2013, 12:06:48
Very true......tho you could use distilled water i guess..... :-\
sassanach
Quote from: Taxi Driver on 04 May 2013, 17:11:26
I used that on a 20 year old combi-boiler once thinking it would improve the performance.  Not long after the heat exchanger failed and I had to buy a new boiler....  ::)  :'(
