air con/climate control
Started by pauls, 04 May 2013, 16:58:35
pauls
What if any is the difference.
kevinp58
With climate control you can set temperature and it should stay at that, with air it is cold or not.  :y
Taxi_Driver
Quote from: kevinp58 on 04 May 2013, 17:11:26
Also alters fan speed auto as well. Also on omegas if you set the recirc air button so that it displays an 'A' on the display, it will shut off the outside air, if it detects any nasty smells coming through the vents  :y
