Author Topic: Which timing kit will I need  (Read 1820 times)
frenchtony
  • vallauris, france
    • omega 3.2
« on: 07 May 2013, 20:09:07 »
Hi
I'm about to change the timing belt on my Omega 3.2.
No-one seems to know which kit I need.
 The VIN is W0L0VBM6921046596 engine Y32SE number 08645562.
It has air con too
thanks in advance
Re: Which timing kit will I need
« Reply #1 on: 07 May 2013, 20:12:22 »
It's the kit that has one eccentric idler & one fixed
« Reply #2 on: 07 May 2013, 20:15:04 »
If the backplate ID is different, swap over the backplate (but keep the new bearings/tensioner, obviously)
« Reply #3 on: 07 May 2013, 20:57:16 »
This is the one you need mate http://www.buypartsby.co.uk/details/VAUXHALL/OMEGA/3.2/2003/__/54/CT990K2/timing-belt-kit/ - these are Contitech kits (Vx oem supplier).  Used a few of these myself - never had any prolem with them.  HTH :y
frenchtony
  • vallauris, france
    • omega 3.2
« Reply #4 on: 07 May 2013, 21:19:35 »
great thanks for the advice dbug I'll order that one up.
Any recommendation on the timing lock kit. I live in France so won't be able to rent one so I'm looking for one for this one off job rather than a keeper, thanks
« Reply #5 on: 07 May 2013, 21:29:42 »
Although I'm coming to French France on holiday you're a bit far away to do a detour to lend you mine  ;) ;) ;)
frenchtony
  • vallauris, france
    • omega 3.2
« Reply #6 on: 07 May 2013, 21:40:06 »
guess I'll have to buy one then resell, which one to get is the next question?
I am down in the deep south of france, mind you it's lovely here!! 8)
« Reply #7 on: 07 May 2013, 21:47:02 »
This is the type you need - http://www.ebay.co.uk/itm/Sealey-VSE130-Petrol-Engine-Setting-Locking-Kit-Saab-Vauxhall-Opel-V6-Belt-/320863290167?pt=LH_DefaultDomain_3&hash=item4ab4f14337 - this is a bit pricey IMO - if you're not in a hurry wait and you should get one for around £50 :y
« Reply #8 on: 07 May 2013, 21:52:07 »
I know you've only just joined ..... but we can go off people!  ::) ;D ;D ;D ;D ;D
« Reply #9 on: 07 May 2013, 22:14:40 »
Nice part of the world mate, and handy for Cannes :y
frenchtony
  • vallauris, france
    • omega 3.2
« Reply #10 on: 08 May 2013, 12:45:24 »
I'm 10 minutes from Cannes, like it a lot here. But apparently you had a nice day Monday there so don't be greedy, too much sun isn't good for you!
I need to do the job in about 3 weeks so maybe a cheaper set will come up thanks for the advice Dbug
