Exhaust Supplier's
Started by omega3000, 07 May 2013, 20:53:30
Where is the best place to get an exhaust , fitting it myself so just need it delivered . Im looking for a down pipe but on mine its an all in one with flexi and cat . "Can it be repaired"  :-\  its got a heat shield thing over the split pipe  :(  Egay have them but not sure on quality although most seem to have a 2 year warranty . Vectra 2.0 140 , 2000 plate .
henryd
If it's just the flexy pipe that's gone you can buy them separately,just need to find someone to weld it in :y
other rides
Quote from: henryd on 07 May 2013, 20:57:18
The down pipe has split and there is a heat shield welded over the split , only thing i thought was hacking the heat shield off and getting the down pipe welded up . But its getting louder and does sound like the flexi also .. will try and get it up on the ramp for further inspection ..
Exhaust putty it is then  :D
bored bigyin54
