Author Topic: eml light again  (Read 1913 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
eml light again
« on: 08 May 2013, 01:49:57 »
help the eml light came on again but i cant work out the codes after doing the pedal trick
2001 MV6 3.2 manual been converted from 2.6 auto
Re: eml light again
« Reply #1 on: 08 May 2013, 09:11:52 »
10-4-2-10
10-4-3-10
10-7-10-4
0420, 0430 both common on the DBW cars .. loads of info about them.. can be ignored, but will hide "other" problems as the light stays on - Decent fuel and a hard drive "might" clear them ... but they will return
0704 Clutch Switch Input Circuit Malfunction
Can't answer that one as I don't have a clutch !!!
Re: eml light again
« Reply #2 on: 08 May 2013, 09:27:43 »
Clutch switch can probably be ignored on a 3.2 manual if cruise is not fitted or working normally, which leaves us with the usual pre-cat issue.
bigtow
  • rochester kent
Re: eml light again
« Reply #3 on: 08 May 2013, 09:38:18 »
thanks guys its just very odd that it came on the day i get a pair of modded 3.0 downpipes delivered . any advice on removing the 3.2 downpipes do the bolts from the manifold to the down pipe have a habit of snapping ?
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: eml light again
« Reply #4 on: 08 May 2013, 10:20:22 »
Easiest way to remove down pipes is when hot.
Try to crack the nuts first by either trying to tighten up or undoing them when cracked spray threads with oil and spin nuts off,
On reassembley put copper slip on threads and use new nuts n washers m10 nuts.
Hoof'land storeman.
bigtow
  • rochester kent
Re: eml light again
« Reply #5 on: 09 May 2013, 03:07:40 »
apart from the light on and high fuel consumption what other issues can be attributed to this fault ?
Re: eml light again
« Reply #6 on: 09 May 2013, 18:34:40 »
The fault will not cause any issues, including high fuel consumption.
bigtow
  • rochester kent
Re: eml light again
« Reply #7 on: 10 May 2013, 02:33:59 »
bugger what could be causing the high fuel consumption poor running when cold  and hesitation under certain conditions that wont throw up a trouble code . when the light came on i dipped the clutch and the engine did not like revving past 5k but when in gear it would pull cleanly through  to the red line ?
