Author Topic: what's this plug for? (by front shock mounting)  (Read 5827 times)
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
« on: 08 May 2013, 14:59:01 »
Anyone know what this is for? (2.6 V6 Elite). It joins the cable by the front shock mounting.  Looking at the corrosion on the connections it doesn't seem to have been plugged in for a long time.
Re: what's this plug for? (by front shock mounting)
« Reply #1 on: 08 May 2013, 15:13:44 »
Looks like power sounder?
« Reply #2 on: 08 May 2013, 16:45:19 »
Is the coolant level sensor plugged in :-\ looks a bit long to be the power sounder :-\ what colour are the wires? Cross reference them with Mr Haynes and it should tell you :y
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #3 on: 08 May 2013, 17:21:34 »
yeah I think that looks like coolant level sensor too
RIP Paul Lovejoy
Big_Al
« Reply #4 on: 08 May 2013, 17:45:44 »
Bonnet switch IMO .. Seems the switch is not there  :-\ :-\ :-\
It sits between the coolant tank & the brake fluid reservoir  usually on F/Lifts
dbdb
  • west london
« Reply #5 on: 08 May 2013, 17:48:30 »
Its not the power sounder I removed that,  blanked off the plug and tucked it away. The flexi conduit has a green stripe on it, the two wires are both brown one with a green stripe.  I can't see anywhere it could plug in.
Here is where the mystery cable joins the other cable, the smooth round silver hump is the top of the o/s shock mount.
I can't locate a water level sensor connected to the expansion tank is this it in the middle of this pic?
If so it is connected.
« Last Edit: 08 May 2013, 17:51:12 by dbdb »
dbdb
  • west london
« Reply #6 on: 08 May 2013, 17:52:47 »
Do you mean the bonnet alarm spring switch, that is on the other side but I will check it is cabled later.
« Reply #7 on: 08 May 2013, 17:55:59 »
The later 2.6 & 3.2 cars I've seen under the bonnet of, have, for some unknown reason, had a 'spare' bonnet switch plug on the passenger side of the car & the actual alarm bonnet switch on the driver's side.
The header tank float wiring is obvious if you lift the header tank up out of the way (just a spring clip on the wing side of the tank)
« Reply #8 on: 08 May 2013, 17:59:16 »
Can't see the coolant level plug in that pic. The sensor is directly beneath the cap :y
dbdb
  • west london
« Reply #9 on: 08 May 2013, 18:10:47 »
Right I have lifted the expansion tank and there is a connection under it (well hidden!), all plugged in so it's not that.  Checked the bonnet alarm switch (on passenger side)  that has a connector all plugged in.
I think it must be as Andy B says, spare bonnet alarm wiring.  It does look as it it has never been plugged in to anything.  Odd that VX didn't blank it off though.  However it is on the driver side not the passenger side  on my early facelift 2.6. My bonet alarm switch  is definitely on the passenger (left) side
« Last Edit: 08 May 2013, 18:13:43 by dbdb »
« Reply #10 on: 08 May 2013, 18:12:02 »
Either coolant sensor plug (feel underneath expansion tank) or more likely bonnet switch plug.  As said most later facelifts have bonnet switch on drivers side.
« Reply #11 on: 08 May 2013, 18:12:40 »
:y :y
Big_Al
« Reply #12 on: 08 May 2013, 18:13:20 »
Just checked mine . Bonnet alarm is on the drivers side between coolant tank & brake res. no spare connection on passenger side though :-\ :-\ :-\
« Reply #13 on: 08 May 2013, 18:16:47 »
When GM decided to factory fit bonnet plunger on driver`s side (later F/L) they "lost" the passenger side ;)
dbdb
  • west london
« Reply #14 on: 08 May 2013, 18:17:34 »
thanks for the responses.  I didn't know bonnet alarm switches (the pop up switch) have been moved to the drivers side on later UK spec cars, mine is on the passenger side as was my 2.5.  So I assume VX put the wiring in the drivers side before they moved over to drivers side switches.
