Author Topic: Sticky buttons...  (Read 3006 times)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Sticky buttons...
« on: 09 May 2013, 00:57:07 »
Boot release, headlight switch, radio button, drivers side electric windows switches.. and many other areas are covered in some kind of sticky substance which I've had no luck in removing, They are mainly in the soft touch areas..
Any ideas apart from replacing buttons which I might do for the boot release as its really ingrained  :-\
Re: Sticky buttons...
« Reply #1 on: 09 May 2013, 01:19:03 »
Try some Ambersil Groom Foaming (upholstery) cleaner, lifts the crud off moist surfaces :y
If it's really horrible, then white spirit :y makes you wonder about the rest of it though :-\
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #2 on: 09 May 2013, 01:27:51 »
I'm amaized how some people can be so dirty in a above avarage car, would expect stuff like this in a corsa, astra etc.. It's horrible using the parts covered in whatever the hell the sticky stuff is which could be anything  :D ;D. Strangely everything in the back sticky free  ;D.. Will look into Ambersil  :y
Found this while searching on google...
http://www.halfords.com/webapp/wcs/stores/servlet/ProductMobileDisplay?catalogId=10151&storeId=10001&productId=250793&categoryId=255236&langId=-1
« Reply #3 on: 09 May 2013, 01:32:16 »
Ambersil will be on the shelf next to it :y If that doesn't shift it, I'll personally bring you some clean switches :y
I probably wouldn't get that desolvit stuff too close to the soft touch surfaces :-\
SMD
  • London
    • :( nowt
« Reply #4 on: 09 May 2013, 10:23:11 »
What an awesome guy! Can you come and fix my coolant leak?  ;D
Selseybill
  • La Rochelle
    • 2.0 pre face, 2.2 CDX est
« Reply #5 on: 09 May 2013, 12:13:48 »
Baby wipes work a treat
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6 on: 11 May 2013, 23:18:15 »
Tried everything still won't come off, Soft touch has come off the boot switch, have bought some buttons off ebay  :-\
« Reply #7 on: 11 May 2013, 23:31:55 »
Should have said, got plenty here
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #8 on: 11 May 2013, 23:33:19 »
Will let you know if i need any more Rob  :)
« Reply #9 on: 11 May 2013, 23:33:54 »
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« Reply #10 on: 12 May 2013, 12:28:35 »
I think it's the soft coating been cleaned with something that's mad it sticky...
I just ended up replacing them...
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #11 on: 12 May 2013, 15:36:29 »
Yeah it looks that way :-\
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 12 May 2013, 15:42:03 »
try this first--It works mate-save your cash :y
Page created in 0.057 seconds with 16 queries.
