Bit of help with a part please
Started by btc, 10 May 2013, 18:33:56
btc
Evning all I have when and got myself a carlton diplomat 3.0 24 valve and am in need of the fuel pipe that conects to the injection system any ideas where I may source said pipe tried VX and the parts guy ask if I was serious thanks
Dazzler
Is it standard rubber fuel hose or the metal feeder rail?
btc
It is the metal fuel rail I have plenty of the ruber hose the metal pipe into the fuel rail is pissing out
tigers_gonads
Are you a member of Autobahnstormers ?
Should get a answer on there if your a member  :y
If not, a few lads on here are active members and may be able to help  :)
I'd update the subject line with the make of car.
You might get a few more replies  :y
Quote from: btc on 10 May 2013, 18:33:56
Contact Andy Clears at Drive Bury St Edmonds http://www.omegaowners.com/forum/index.php?action=profile;u=1488
If he can't help ...... no one can  :y :y :y
btc
Thanks for the quick reply lads. :y will give any a call on Monday anymore idea welcme
