I'm no mechanic but.......
Started by Field Marshal Dr. Opti, 11 May 2013, 17:41:58
I'm proud of the work I did on Mrs Opti's beloved Corsa this afternoon. Without too many problems, I changed both the pads and discs, using genuine GM parts (£65)
Vauxhall wanted 90 minutes labour to do the job. That's £108 alone  :o :o :o
Pat on the back for Mr Opti I think, as I'm just about the most inept mechanic in the whole of the UK :y :y
Why? What was wrong with the old ones ;D
Seriously though, jobs (and savings like that) make for most satisfying afternoons  :y
symes
Well done Mr Opti  :y :y Too right-you should be proud of yourself :y :y
Quote from: symes on 11 May 2013, 17:45:57
Thanks, Mr Symes. :y
The caliper bolts were s*** tight.
Quote from: ex taxi al on 11 May 2013, 17:45:34
Agreed, TD.........Large amounts of expletives followed by that nice warm feeling. ;D ;D ;D ;D
amba
Well done that man and a good saving. :y
Satisfaction knowing you have done the job yourself and certainly better than most garages would have done. ;) :)
ozzycat
well done mr opti next youll be changing engines  :y :y :y :y :y
long live the magic tree
its good to be back
Toledodude1973
It is the knowing YOU fixed it which is good , pads and discs can be horrible well done
2002 omega slowly morphing into 2003 omega with increasing doner parts fitted
Taxi_Driver
I bet he's loosened the brake pipes while he was there  ;D ;D :D :D
I've just treated myself to a bottle of 10 year old Laphroaig....... :y
Cheers all. :y
Quote from: Mr. Opti on 11 May 2013, 19:13:34
Cheers all. :y
:o before tea... I know it's Saturday, but really ;D
Taxi_Driver
Cheers all. :y
Has the 'loosening the brake pipes' worked already then  :y ;D ;D ;D
Quote from: Taxi Driver on 11 May 2013, 19:16:11
Cheers all. :y
Certainly not hedging his bets ;D
Taxi_Driver
Quote from: ex taxi al on 11 May 2013, 19:17:48
Cheers all. :y
And probably dancing around the room with Mrs Opti's million pound life insurance cert  ;D ;D :D
Cheers all. :y
There was this strange coloured fluid leaking everywhere but I took no notice. ;D ;D ;D :y
