Author Topic: Tyre Sizes  (Read 2379 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
Tyre Sizes
« on: 12 May 2013, 18:52:52 »
If say for example I wanted to run a set of alloys that measured 8.5in on the front and 9.5in on the rear, what size tyres could I safely run without worrying about rubbing?
My chart gives these sizes:
8,5 Inches
Minimum   Normal              Maximum
225 mm   235 or 245 mm   255 mm
9,5 Inches
Minimum.  Normal.             Maximum
245 mm   255 or 265 mm   275 mm
Re: Tyre Sizes
« Reply #1 on: 12 May 2013, 19:14:02 »
If the car is lowered anything over 235 will rub the fronts :-\
Re: Tyre Sizes
« Reply #2 on: 12 May 2013, 19:17:46 »
Some 235/45/17 tyres on factory wheels rub. These, from memory, are 7.5J.  Without looking, I don't know what the ET of factory rims are.
Some 245/40/18 on Irmscher Sportstar ET30 will rub.
8.5J, I think you *may* struggle, but depends on the offset. But it may be too tight to avoid the wheelarch at one end, and strut at other end of the offset scale.
Re: Tyre Sizes
« Reply #3 on: 12 May 2013, 19:33:28 »
17"s are ET33 iirc :y
My 8J 18"s have 245/40/18s fitted, ET33 and no rubbing, but set up is standard Plod :y
Re: Tyre Sizes
« Reply #4 on: 12 May 2013, 19:40:50 »
anything over 235
* handling will be awful (especially on a lowered car)
* will cost serious money with premium brands
* not worth it because will losse acceleration performance
* will probably tramline
imo :-\
« Last Edit: 12 May 2013, 19:42:33 by cem »
Re: Tyre Sizes
« Reply #5 on: 12 May 2013, 19:44:24 »
anything over 235
* not worth it
imo :-\
Not wishing to be difficult ::), but mostly wrong IMHO :-\ Only thing agreable is that tyres can get pricey :y
But Paul probably already knows that ::)
Re: Tyre Sizes
« Reply #6 on: 12 May 2013, 20:16:03 »
anything over 235
* not worth it
imo :-\
Not wishing to be difficult ::) , but mostly wrong IMHO :-\ Only thing agreable is that tyres can get pricey :y
I have tried many monster bimmers (v8-v12) with those monster tyre sizes.. and even those cars become awful with those tyres..
let alone omega :-X
P6UL K
  • Dartford, Kent
Re: Tyre Sizes
« Reply #7 on: 12 May 2013, 20:21:25 »
Tyre cost isn't an issue, otherwise I wouldn't be considering it! Cheers Al  ;)
Always make me chuckle when you get far more Information than you even asked for lol... Thanks for your concern tho :y
Wheel offset is yet to be confirmed, with the possible future long term plans I have I'm gonna need something to lay a 'certain amount' of power down  ??? And the car is lowered about 30 - 35mm at a guess, not quite sure tbh  ::)
« Last Edit: 12 May 2013, 20:25:58 by P6UL K »
Re: Tyre Sizes
« Reply #8 on: 12 May 2013, 20:25:43 »
sorry.. couldnt resist ;D ;D ;D
P6UL K
  • Dartford, Kent
Re: Tyre Sizes
« Reply #9 on: 12 May 2013, 20:26:38 »
Yes that's exactly the look I'm going for  ::)
Re: Tyre Sizes
« Reply #10 on: 12 May 2013, 20:27:42 »
Surely you're not going to paint it yellow?  ::) ::) ;)
P6UL K
  • Dartford, Kent
Re: Tyre Sizes
« Reply #11 on: 12 May 2013, 20:38:59 »
Ha ha no! I'm happy with her looks now  8)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Tyre Sizes
« Reply #12 on: 12 May 2013, 20:55:02 »
Yeah normal service has been resumed,a tyre thread  ;D  :y
Hoof'land storeman.
MV6Matt
  • London
    • No car since 2022....
Re: Tyre Sizes
« Reply #13 on: 13 May 2013, 08:11:01 »
8,5 Inches
9,5 Inches
Paul,
I had 235/35/19 tyres on the front about 4 years ago. The wheel was 8.5J at 35ET - no problems with Rubbing at all.
I think you'll have problems with rubbing if you go wider.
I had (at one point) 275/30/19 on the rear. It was excactly the look I wanted. Living with it on lowered suspension was some thing else entirely........
Rears should take 10J
Matthew
(thanks Ian)
Re: Tyre Sizes
« Reply #14 on: 13 May 2013, 08:27:27 »
IME, 30mm is about the absolute maximum for regular road use. Even that is probably too low for the rear. Problems are speed bumps, getting over dropped kerbs onto slopping driveways, the ramps in multistorey car parks etc.
Obviously, if its a show car, none of the above will apply :)
