Author Topic: idea - how to remove stuck hub (on a trailer)  (Read 12335 times)
jonathanh
  • coventry
« on: 14 May 2013, 12:25:14 »
here's the problem: got a brake drum on an ifor williams trailer.  they are sealed unit bearings and try as i might, I cannot pull the drum off.  I've tried a universal hub puller - that's not strong enough.  It's been soaked in penetrating oil and walloped a lot as well.  any ideas?  Anyone within reasonable distance of coventry with a heavy duty puller that wants a challenge?
Any help is appreciated
mantahatch
Re: idea - how to remove stuck hub (on a trailer)
« Reply #1 on: 14 May 2013, 12:29:50 »
Is this any help http://www.youtube.com/watch?v=QKqXL-6ORBA I cannot hear what he is saying as we cannot have sound on here at work.
And this http://ihdg.proboards.com/index.cgi?board=ght10&action=print&thread=110091
http://www.iwt.co.uk/iwt-parts
« Last Edit: 14 May 2013, 12:34:22 by Mantahatch »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #2 on: 14 May 2013, 16:00:50 »
Had a similar thing with a 3 series, hub would not pull out with any device at all, ended up removing the trailing arm and taking the lot to a local hydraulic guy with a 100 tonne press, even that only just shifted the bugger. Cost me 30 all in.
jonathanh
  • coventry
« Reply #3 on: 15 May 2013, 08:25:27 »
thanks both
the hub nut is off ( got 3/4 socket set to do that).  problem with a press is that the axle is welded to the beam so it will not fit a press.
am currently stuck...
cleggy
« Reply #4 on: 15 May 2013, 09:21:26 »
I've probably got this all wrong but wasn't an old trick to remove the wheel put a spanner behind it, remount the wheel and when tightened up it pulled the hub off? :-\
jonathanh
  • coventry
« Reply #5 on: 15 May 2013, 10:39:46 »
hmm, now that might just work.  will give it a try.
failing that I guess i'll sacrifice the bearing
b4ndit
« Reply #6 on: 15 May 2013, 18:28:03 »
a slide hammer may help :y
symes
  • oxford
    • R reg 940 volvo
« Reply #7 on: 15 May 2013, 18:31:53 »
does it have brake shoes in it-if so slacken them off?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #8 on: 15 May 2013, 19:25:25 »
Do you want to borrow Percy (my lump hammer) ?
It fixed my stag usb lead  :-X :-X ;D ;D
