a/c nissan almera tino
Started by pauls, 14 May 2013, 20:58:36
pauls
Am i being stupid or being taken for a ride. wife took her car in for her a/c to be checked.it need a new condensor rad.So i got one and there fitted it and regassed it anyway the bill has  £28 for anti freeze whats that got to do with the aircon
Webby the Bear
Sure it wasn't refrigerant to replenish the stuff lost from possibly leaking condenser?
RIP Paul Lovejoy
pauls
Is their a difference then between the gas and the refridgenant then. I thought that was the gas
Quote from: pauls on 14 May 2013, 20:58:36.... anti freeze whats that got to do with the aircon
Nothing at all  ???  ???  ???
pauls
Andy thats what i thought. Question do they have to drain the antifreeze(radiator) before removing and replacing condensor radiator. Invoice says 50 for air con gas. 28.75 for antifreeze and 30 for labour.
Quote from: pauls on 14 May 2013, 21:47:06
Yes you do .... the a/c condenser is right at the front of the car with the coolant radiator behind it.  :y
pauls
Cheers Andy just thought i was getting ripped off.  :y
henryd
Quote from: pauls on 14 May 2013, 22:41:16
28.75 is a bit strong for antifreeze though,normally £4-5 per litre and that should only need about 3lt for a 50/50 mix
other rides
pauls
Quote from: henryd on 15 May 2013, 11:16:54
Thats what I thought. I will be speaking to them  >:(
I put 4.5 litres in mine. I was led to believe that the cooling system holds about 9 litres.
Ooops, Sorry. You're talking about a Datsun. :-\ :-\
