2.5v6 manual to a 3.2v6 auto. What should I look out for?
Started by megaomega123, 15 May 2013, 13:37:53
megaomega123
Never had an auto before and I believe this is a DBW engine. Car has 60k miles, cambelt changed at 55k with proof, fsh with proof and pro lpg conversion with receipt. It is a 51 plate 3.2v6 Elite
I am paying £1995 for the car is there any niggles or known faults I should be looking for?
Thanks
if you mean checking the car , here you go
* paint :
     any color difference between panels (different angles).. sanding scratches inside the paint.. paint dust inside the door pillars, door, hood edges etc.. unusual white traces inside the engine bay..
* bodywork :
   rusts inside wheel arches, rusts under the doors, door gaps for equality ,
   from front all gaps around headlights, hood must be equal for both sides.. bumper to tyre distances must be equal for both sides (you can measure with your fingers) , absolutely check down the car visually
* electrical
   AC, sunroof, mirrors, windows controls , battery (take a voltmeter with you and measure the charge of car when lights and AC open)
* autobox
   does it make any thump sound when you engage in D
*engine
  check idle when cold and warm must be around 550-600 rpm (also check idle at lpg) , rev the engine and try to hear unusual noises.. check coolant bottle (color and smell).. check oil
* tyres
   any unusual wear/tear , thread depth
* brakes
   check brake discs for wear ..
and drive the car for some miles :y
ps: its a long list so better you check from google..
2woody
remember also to remove your left leg - you won't be needing it
Would say the usual Omega failings:
Odd tyre wear, oil leaks, coolant leaks. Check everything works as expected.
3.2 is arguably a much more robust and reliable lump than the 2.5 :y
Quote from: ex taxi al on 16 May 2013, 11:25:35
Not convinced on that one to be honest
Quote from: 2woody on 16 May 2013, 09:40:52
What would ou press the brake pedal with?  ???  ???  ;)
Quote from: v6miggy on 15 May 2013, 13:37:53....
Thanks
pre cat lambda sensors
Quote from: Marks Hornby 'OO' on 16 May 2013, 11:49:37
+1
Quote from: Andy B on 16 May 2013, 12:48:09
???  what ? you cant be serious ;D :y
Quote from: Kevin Wood on 16 May 2013, 14:16:55
Quote from: Andy B on 16 May 2013, 12:49:01
Thanks
pre post cat lambda sensors
I knew it was something to do with pre/post cats & lambdas  ;D  ;D
