Author Topic: Vauxhall Omega 3.2 Engine stops after 10 seconds and info screen defaults to Ger  (Read 3677 times)
darren757
  • chester
    • 3.2 facelift elite
Dear all,
I hope someone can help.
I have a 2001 Facelift 3.2 Omega.Mileage 80K.
When I start the car usually from cold,the car starts fine ,runs for 10 seconds then stops.
Spanner flashes.
If i turn off then start again engine starts.
Info screen defaults to German as well.
It occasionally does this when warm.
I also have engine light on and codes suggest the precat issue.
Have checked codes and i have
1613
1612
0430
0420
1700.
Its never ticked over smoothly even though all breathers clean,throttle body cleaned,plugs etc are good.
Its had a crank sensor fitted last year.
All fluids are good and no leaks.
I wondered if anyone had a simliar problem and if it could be an ECU issue?
I have checked chip is secure in key and replaced battery in fob.
Or is it all a coincidence  and crank sensor is playing up.
Help!!  thanks
Was the crank sensor replaced with a genuine one?
If not, it might be prudent to do that first and report back :y
Squatch
  • Belfast
Mine has never idled smoothly either, it seems to be an issue on dbw cars..
dbw or not, omegas have many components that can prevent idle to be smooth and perfect..
so you have a long checklist :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
For the idle problem
Can of brake cleaner and a tooth brush for the throttle body and check for split breather pipes
Swap crank sensor for a genuine VX one if not fitted
No DBW V6 ones are, they are all a bit shit!
horsecow
  • Omagh
    • 2.2 dti cdx/3.2 elite
I have the start/stop problem on mine since I got it last yr. Basically the car decides to not recognise the key sometimes, thats what 1612/1613 codes are. If it does this remove the key from ignition completely and wait for a few seconds before re-starting. Not sure how to sort the problem entirely but this will keep you moving and I'm sure someone else will be able to advise how to fix properly.
Drive 'er like yer late for mass!!
symes
  • oxford
    • R reg 940 volvo
+1 :y so much for progress :D
    • 530D M Sport, 330i Coupe
A lot of the idle vibration is down to the exhaust  ;)
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Yep... I wish VX had put that in the marketing literature could have saved myself a few grand over the years  ;D ;D ;D
Darren
Flashing spanner implies immobiliser...
2woody
  • Northumberland
when first starting, put the key in and turn to red lights. Then wait a few seconds till you start it. That did the trick for me
darren757
  • chester
Hello All
Thanks for all your replies.
Appologies for the delay in getting back to you all.
Crank sensor was replaced with gen vx one last year.
Just done 450 miles and it never missed a beat.
Throttle body was cleaned and made no difference to tick over.
Also giving the car a good blast cured the  lamda issue.
Ive tried waiting a few seconds before starting engine and so far no problems.
I wondered if it could have been a mix of a slightly tired battery after first start ,voltage dropping and causing a voltage drop in system....thus the change of language issue and why my german has improved trying to find the english lang setting.
I will advise how the beast performs starting wise.
Thanks again to all much appreciated
