Author Topic: Airbox assembly... does it just lift out?  (Read 1397 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« on: 20 May 2013, 17:01:45 »
Hi guys,
As above.... is the airbox just held in by rubber gromets and after disconnecting from the bagpipe that houses the MAF... i'm assuming I can just pry up on it?
Cheers guys :y
RIP Paul Lovejoy
Re: Airbox assembly... does it just lift out?
« Reply #1 on: 20 May 2013, 17:40:33 »
Correct. :y
Webby the Bear
  • Northampton
« Reply #2 on: 20 May 2013, 17:42:25 »
cheers albus  :y :y :y :y
RIP Paul Lovejoy
« Reply #3 on: 20 May 2013, 18:39:47 »
Yup - 3 grommets, 2 to wing, one at bottom not far from rad.
symes
  • oxford
    • R reg 940 volvo
« Reply #4 on: 20 May 2013, 22:20:50 »
careful of hook part under metal pipe to bottom radiator hose :y
Webby the Bear
  • Northampton
« Reply #5 on: 22 May 2013, 09:29:57 »
cheers for the help guys. box came out without too much fuss but I STILL don't have enough room to swing a 24mm wrench on to the bottom EGR pipe bolt. adjustable wrench head is too thick to sneak between the pipes  ::) ill have to get a short 24mm from somewhere.
ps, that lower snorkel from the air box... is that the tube that sticks up an lives just above the washer fluid tank... looks like a trumpet? lol presuming that's where the air comes in  :)
RIP Paul Lovejoy
« Reply #6 on: 22 May 2013, 13:34:45 »
Aye  :y
