Steering wheel adjustment
Started by mmcg, 26 May 2013, 14:35:54
mmcg
Fitted new track/ tie rod to drivers side 2.2 dti estate, the steering wheel is slightly to the left.Could i adjust the centre  section clock or anti clockwise to get it straight. :-\
sassanach
you need to lengthen the drivers side.its impossible to say which way because they can be fitted side to side as well as back to front.
symes
Tracking not right mate-Hold wheel straight when doing tracking-reckon its out mate-And no you cannot adjust centre link-it is solid
sassanach
i presumed the centre section he was refurring to was the bit connecting the two ball joints at the drivers end .
symes
Ooh silly me got wrong end of stick -thought OP on about centre bar adjustment--sorry :-[
mmcg
Sorry I meant the middle section with the two pinch bolts between outer and inner balljoints.If i turn the middle  section clockwise it should lengthen  it. :-\ :y
slowboy
Symes is correct tracking out
sassanach
symes
When changing track rods-you need tracking gear or go and get it done-WIM is where most recommended-I do my own as got tracking gear  :y
mmcg
I will get a full geometric setup when  I do further work.Idler arm next and might as well change left side track rod.Bought a 96 x20xev for spares ,it has two new lower control arms would they fit 02 dti.
CG2
Why is there a guide section on this site...? No bugger reads it, it seems.  :(
symes
Quote from: Joe Bloggs on 26 May 2013, 23:45:28
I know what you mean-quite helpful stuff in there  :y
