Author Topic: help needed 3.2 manifolds on 3.0  (Read 2576 times)
djhorner
  • isle of lewis
    • omega mv6
« on: 26 May 2013, 17:47:09 »
right i am just about to put these 3.2 manifolds on my 3.0 but there are pipes on the 3.0 ones but not on the 3.2 no idea if i can put the 3.2s on now
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Re: help needed 3.2 manifolds on 3.0
« Reply #1 on: 26 May 2013, 18:02:26 »
H, sorry what pipes are you referring to  :y
Darren
RobG
    • 16 plate Mokka. Vivaro
« Reply #2 on: 26 May 2013, 18:05:01 »
Guessing SAI pipework
djhorner
  • isle of lewis
    • omega mv6
« Reply #3 on: 26 May 2013, 18:08:48 »
not sure but its aluminium pipes going into both manifolds two outlets on manifold into one pipe then go's round front on engine
RobG
« Reply #4 on: 26 May 2013, 18:10:05 »
SAI system. Rip it out, not needed
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #5 on: 26 May 2013, 18:56:20 »
Agreed.
I have fitted the 3.2 manifold to my 2.5.
It is important to get the correct manifold gaskets for the 3.2 as the standard 3.0 ones will allow a blow at the mating face. You can also lose the Y shaped pipework from the front of the engine that connects to the now missing pipes.
You will also need to unplug the electric SAI motor - it's bloody loud once the pipework is gone!
djhorner
  • isle of lewis
    • omega mv6
« Reply #6 on: 26 May 2013, 19:47:33 »
what is this sai and what does it do
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #7 on: 26 May 2013, 19:54:06 »
Secondary Air Injection.
It blows clean air into the exhaust manifold, presumably to reduce emissions.
It's crap though, and you won't miss it once it's gone.
« Reply #8 on: 26 May 2013, 21:52:11 »
.... and what does it do
just there to appease tree huggers  ::) ::) ::)
djhorner
  • isle of lewis
    • omega mv6
« Reply #9 on: 26 May 2013, 21:55:10 »
what other bits do i need to remove? aside from pipes from manifolds
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #10 on: 26 May 2013, 21:59:10 »
the fuse for it and if you like the pump from under the front n/s bumper, power to wieght and all that
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
