Author Topic: Aux Belt Tensioner.  (Read 17663 times)
CG2
Re: Aux Belt Tensioner.
« Reply #30 on: 27 May 2013, 01:35:38 »
Clearly I'm the only one that thinks something's rubbing on the cam belt cover....?
If its was tensioner pulley related the noise would be twice or even three times quicker, no?
It is the tensioner pulley I've ruled it out to be that but will be 100% sure soon enough  :y
Ruled out? In what way..? :)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« Reply #31 on: 27 May 2013, 09:53:50 »
I have had two fail and it's very annoying. The bearings seize, the plastic pulley melts and the belts get shredded. No water pump, no alternator, catch bus home. It demonstrates the wisdom of changing the cam belt pulleys every 40000 miles. They are cheap - about £20 from memory.
« Reply #32 on: 27 May 2013, 12:37:44 »
I've said many times before I would but no point no VX accept it around here.
Slaters Llanwnda are listed on the Tradeclub website, IIRC, you said you were near Anglesey?
https://www.tradeclub.com/home/about/retailer-locator/Search
« Reply #33 on: 27 May 2013, 14:00:21 »
So are Slaters of Colwyn Bay, about 20 miles from Anglesey ;)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #34 on: 27 May 2013, 15:11:27 »
Weather too bad so far to grease the pulley.
Looks like Slaters have signed up to TC then last time I asked they had no Idea what autobarnstormers tc discount where. I'll look into it when I have time. Thanks  :y
Typical this weather would be raining and windy  :(
« Reply #35 on: 27 May 2013, 16:48:27 »
Thats a b*gger mate, lovely blue skies all day over this way, but a touch windy
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #36 on: 27 May 2013, 17:09:24 »
Yep, checked the weather should be nice all week here  :)
« Reply #37 on: 27 May 2013, 19:00:26 »
They won't know what Autobahnstormers TC is, as there is no such think.
With ABS you get a card that has a TC account number on it (on a sticker in ABS's case). They just need to set up that TC number on their systems (if somebody else hasn't already). I believe ABS give you the number of their TC account rep for the dealer to call if they need to verify its legit.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #38 on: 27 May 2013, 19:02:52 »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #39 on: 27 May 2013, 19:03:39 »
Looks like the weather is clearing up might try and whip the pulley off now  ;D
« Reply #40 on: 27 May 2013, 19:13:55 »
Less than 10 mins mate :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #41 on: 27 May 2013, 19:34:14 »
Pulley off, There is play and a roughens feeling when spinning the pulley on my finger  :y
« Reply #42 on: 27 May 2013, 19:36:31 »
While it's off, stick a bit of grease under the dust seal ...... it won't mend it, but it'll help till you manage to get a new one  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #43 on: 27 May 2013, 19:38:18 »
Think i'll leave it till i get a new one, anyways i've got the 2.2 and the korean box for the daily stuff till the 3.2 fixed  :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #44 on: 29 May 2013, 14:12:38 »
Got the part today, will be fitting it this afternoon  :y
