Fuel rail pressure.
Started by CG2, 26 May 2013, 23:43:02
Quote from: Joe Bloggs on 27 May 2013, 17:43:32
Need 4.15 bar from the same system.
Possible?  :)
Worth a call to those useless chavs at Courtney. They sell higher rated fprs, without understanding why it will do 3 parts of shag all in the application they sell it for. Might suit your requirements though  :-\
.. as to whether the pump is man enough, what you need to do is get a FPR set to your desired fuel pressure, connect it to the system and then measure the flow rate out of the return line. Time how long it takes to fill a 5L petrol can, for example.
There are various ways to work out the required flow rate for your engine based on expected power output. Just make sure you've got a sensible margin of flow above that (say 50% or so).
Fuel pipe diameter will have a bearing on flow rate vs pressure :-\
Would the fuel pipes/filter/pump from an early 2004 Monaro do the trick :-\
biggriffin
Very criptic,but me think as a few others Ls 1.
Yes would fit with some minor mods,and be easier to transplant it still on front subframe,to gauge what mod needed,to transmission tunnel.
Hoof'land storeman.
Quote from: ex taxi al on 28 May 2013, 12:52:33
Am I correct in thinking that the pressure marked on the regulator is the pressure of fuel required to open the valve within the regulator?
If so, pop a 5 bar regulator into an Omega fuel rail and see if the fuel pump can deal with it :y
If it can't, then you need a more potent fuel pump :y
biggriffin
Oh to add an omega with an Ls1 fitted,was called a clubsport available.downunder. :y
Hoof'land storeman.
Quote from: biggriffin on 28 May 2013, 14:36:17
Sorry to dissappoint you, but the Commodore is only vaguely related to the Omega. The only parts that I know of which are fitted to both cars are the rear wheel bearings. They are the same on both the Commodore and the Omega B estate :y
biggriffin
It bears a simalar resemblance. Part of the floorpan and rear doors,and some other interior trim. Not worth spliting hairs, built by gm tho.
Hoof'land storeman.
symes
reckon you need Moroso pump and regulator- I got little one on rover 70gal per hour iirc
If it is available, take the FPR off the new engine and fit it to a V6 Omega. Then if it starts take it for a drive and see if the Omega fuel pump can keep up :-\
Either way your question will be answered :y
biggriffin
Quote from: Chrisgixer on 28 May 2013, 23:39:32
Urm 1st mr cixer is jo bloogs then he becomes cixer again,now he answering his own post.help the llunitics are running the asylum. ;D :D
Hoof'land storeman.
I think you've confused yourself ;D
