Fuel rail pressure.
Started by CG2, 26 May 2013, 23:43:02
CG2
Anyone now the stock fuel rail pressure on omega?
3.2 lump.  :)
CG2
Oooooh, just shy. Need 60 psi.  :-\
Quote from: Joe Bloggs on 26 May 2013, 23:50:01
Out of interest, why?
CG2
If the pump is designed to deliver 55 PSI I'd say it'd stretch to 60 with a different FPR... and a different engine, of course, because increasing the fuel pressure on a standard V6 is a hiding to nothing. ;)
Johnny English
Retrofitted an AutoGauge fuel press gauge, which indicates 3,0 bar when starting and 2,2 - 2,3 bar on normal run.
C20NE - X25XE
Doesn't the replacement engine come with the correct FPR that it needs, or is this being done piecemeal?
Kevin Wood does present a valid point - is the in-tank pump man enough, or would you be pushing that a bit hard. Certainly wouldn't want it going lean at WOT.
Does the pipework and filter allow enough flow? Looks to be a few gotchas that are out there that could trip you up.
CG2
Quote from: Andy B on 27 May 2013, 10:00:15
Quote from: Joe Bloggs on 26 May 2013, 23:58:59
Quote from: tunnie on 26 May 2013, 23:57:52
Because 55psi is too low. :)
Too low for what?  ???
Too low for 60psi! Silly! ;D
That's a difference of 5psi. Nosey Parker! ;)
CG2
Had a 3.2 inlet manifold in my hand today, had 3.8 bar printed on it.  :y
Got a 3.2 injector rail sat on my bench and it is also 3.8 bar. I guess that's decided then. :y
CG2
Need 4.15 bar from the same system.
Possible?  :)
If most of your replies are cryptic how do you expect answers ???
martin42
more info would be use full,its like saying what heating pump will suit my heating system with out know how many rads,how many floors etc,please be helpful,we cant give advise if you dont tell us!!!!!!!!!!
and it also wastes members time and also the WRONG advise can also be given!!!!
