Friends car - is this a dodgy PAS pump? (Hyundai Coupe)
Started by Webby the Bear, 29 May 2013, 12:44:05
Webby the Bear
Hi guys,
See this vid of my mates' 2.0L 04 plate Hyundai Coupe...
It's obviously squealing quite bad. There's a faint squeal at idle when wheel is straight but as soon as you turn left full lock it starts howling like a mental case (does NOT happen when full lock right).
I lubricated the belt to see if it was perhaps the belt itself but it didn't have any change. The belt is perfectly tensioned as well and the belt is in good condition. Nothing is loose.
When my mate first showed me the problem whilst turning left the pulley actually slowed down and then STOPPED briefly before spinning again making an even worse racket!  :o
So where to go with this... is it a PAS pump or could it be a problem with the rack?
Cheers guys  :y
RIP Paul Lovejoy
Webby the Bear
Ps, I just played back the video and although the squealing is quite low that's clearly just a bad video.... in real life it was howling like a wolf!  :D
RIP Paul Lovejoy
Webby the Bear
PS, PS, (sorry lol)
this is the pump assembly from the back so if it is a replacement then presumably its a simple case of taking the belt off and removing those fasteners at the back and replace pump :)
RIP Paul Lovejoy
henryd
If the pulley stops under load either the belt is knackered or loose,those rib belts need to be proper tight :y
other rides
slowboy
If the steering does not have tight spots to coincide with the noise it may not be the pump but the belt ,retension
Webby the Bear
Cheers guys. thing is though the belt is really tight... so tight in fact I actually thought ''f... me that's too tight''
RIP Paul Lovejoy
Webby the Bear
just to add some additional info... theres no play in the tie rod ends on either side. and the steering when done by hand is nice and light
RIP Paul Lovejoy
martin42
easily fixed for less than a £5 some petrol and matches problem fixed and never rear its head again all sorted  ;D ;D
Webby the Bear
lmao that is an option I suppose martin  ;D ;D
I think what ill do is alter the tension and if that doesn't solve it (got my doubts as the belt is perfectly tensioned) ill replace the pump  :y worst case scenario is that doesn't fix it and he can re-sell the part on eGay  :y
RIP Paul Lovejoy
martin42
them belts do have to be done tight but fing tight tho,get it tighter 1st before condeming the pump
Webby the Bear
Quote from: martin42 on 29 May 2013, 19:04:31
Will do. cheers martin  :y
i'm presuming all I do is loosen that red looking fastener and pull the PAS pump to tighten it more then tighten the fastener up again? i'm thinkin I may also have to loosen up that bottom one too  :-\
RIP Paul Lovejoy
symes
Webby its noy belt-pump is f*******d mate - thats ya problem :y :y
Webby the Bear
Quote from: symes on 29 May 2013, 20:39:28
that's what I thought mate  :y defo worth getting it as tight as pos first though. rule that out and then swap it out. theres a awesome youtube vid of how to do it... piece of piss!  ;D :y
RIP Paul Lovejoy
