Author Topic: Leaking rocker gasket  (Read 1681 times)
rockindave
  • Oxfordshire
    • Omega
« on: 01 June 2013, 20:33:12 »
Hi Guy's
I have just purchased my first Omega 2.5 V6 CDX Auto,But I have a leaking rocker cover gasket is this an easy fix I mean can I do it myself instead of getting it into a garage.....Cheers Dave :-\
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
Re: Leaking rocker gasket
« Reply #2 on: 01 June 2013, 20:38:56 »
easy to do, ive just replaced my elite ones and mv6 waiting for hers to be done
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
Big_Al
« Reply #3 on: 01 June 2013, 20:41:42 »
Have a  look at the guide in the maintenance section . If you follow it to the letter you won't go  wrong .
Genuine VX gaskets are a must  as is the black sealant.  Cam cover torque setting is also critical .
If you do you own maintenance you should be able to do this .
HTH :y
  • Auckland
    • Mazda MPV
« Reply #4 on: 01 June 2013, 20:47:44 »
I'm guessing you haven't found the maintenance guides :-\
Maintenance Guide Index
Changing the gaskets isn't rocket science but you will need a set of Torx bits and a little torque wrench.
Changing the Cam Cover Gaskets
The cam cover gaskets begin leaking when the breather system blocks up. Clean the breathers before you change the cam gaskets and then every year.
Cleaning the V6 Crankcase Breather Setup
[Edit] must type faster...... [/Edit]
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
« Reply #5 on: 01 June 2013, 20:49:54 »
hi & welcome :y
symes
  • oxford
    • R reg 940 volvo
« Reply #6 on: 01 June 2013, 21:38:41 »
hello and welcome  :y +1 Andy H is correct :y
