Author Topic: omega 2.6 v6 elite  (Read 2752 times)
rogisok
  • Melton Mowbray
    • Omega petrol estate
omega 2.6 v6 elite
« on: 02 June 2013, 10:18:53 »
How to completely disable a malfunctioning alarm, power sounder has been disconnected, bonnet sensor has been disconnected, alarm is quiet for weeks, them randomly activates for no apparent reason, even when deadlocked with 2nd application on remote.
    • E250 Est / Elroq
Re: omega 2.6 v6 elite
« Reply #1 on: 02 June 2013, 10:25:27 »
Not very easily...Have you had the alarm codes read to see what the trigger is?
As youve an estate, I would be guessing at the rear / boot window sensors.
flyer 0712
« Reply #2 on: 02 June 2013, 10:34:36 »
Remove power sounder altogether  from the car and bin it  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #3 on: 02 June 2013, 11:17:29 »
+1 throw power sounder away mate-can still BBQ ya car while in there :y many miggy's gone up in smoke due to the powersounder :(
rogisok
  • Melton Mowbray
« Reply #4 on: 02 June 2013, 11:21:26 »
Just found this for a Zafira, does anybody know if it works for an omega???
It won't fix the cause, but to shut the thing up, turn to page 184 in the operators manual.. find the fuse map.. there should be 5 rows of 9 fuses... all colour coded.. top left, nearest the big fuses (which I have ignored) is fuse 6, to fuse 14 at the other end of the row.. 15 is under 6, going to 23, and so on.
Pull out #13 <5amp>(top row second in from right) Pull #15 <5amp>(second row, furthest left
Pull out #21.. <5amp>immediately under where #13 was Pull #32 third row, furthest right (20amp)
This will neutralise the alarm, but keep the central locking.. DON'T leave the fuses in the car.. take them inside, and contact the garage at a more socialble hour.. this wil allow you to drive the car, saving a small fortune in pick up fees.
    • E250 Est / Elroq
« Reply #5 on: 02 June 2013, 11:45:24 »
To my knowledge there is no fuse to silence the alarm...wouldnt be a very good system if a thief knew to remove 2 fuses for silence!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #6 on: 03 June 2013, 10:56:59 »
And wouldn`t exactly be a great idea to publish how to disable the vehicle security on a public forum either now, would it?
 ::) :-X
Radio & Decoding Technician
www.dndservices.co.uk
flyer 0712
« Reply #7 on: 03 June 2013, 11:13:33 »
As stated earlier...although disconected many an omega gone up in flames as they still have batteries inside the unit and they corrode ..best thing ..bin it.. :y
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #8 on: 03 June 2013, 14:41:47 »
as a previous poster put it will be the rear glass sensors, the conectors just pop off and get dirty over time so loose conductivity, if you pull wires off window the alarm will think its a saloon and revert to that state, i know been there with both mine and now silence is golden
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
