Pages: 1 [2] 3  All   Go Down
Author Topic: Engine squeal  (Read 5312 times)
Iain
Re: Engine squeal
« Reply #15 on: 04 June 2013, 15:14:15 »
Yeah the engine was cold in the 1st 2 videos, no squeak present.
took it for a run and now its warm.....
http://www.youtube.com/watch?v=4W7FzfwQ3-8&list=UUt8HiOyLVAw5qJHNu8rz6tg&index=1
You can hear the squeal better towards the end :y
dbdb
  • west london
  • Tramlining,Trade Club,WIM,my time racing,Linux etc
    • f/l elite 2.6 V6 manual
Re: Engine squeal
« Reply #16 on: 04 June 2013, 16:22:03 »
That's more of a squeak than a squeal.  A slipping fanbelt is quite a distinctive squeal, a shriek almost, not like that and will happen particularly when you rev it.  If that is the case spraying some anti slip on it will stop the noise but carry a spare belt as the belt will go soon.   However your squeak sounds like a bearing noise.
« Last Edit: 04 June 2013, 16:23:55 by dbdb »
dbdb
  • west london
Re: Engine squeal
« Reply #17 on: 04 June 2013, 16:28:47 »
Obviously it is difficult to tell where it is coming from in a video but just in case put a stethoscope on the timing belt cover (or briefly run without the aux belt as suggested) and make sure it is not ththe timing belt, the most expensive problem if not fixed.  My timing belt made a lot of noise when it was going.  Not like that squeak though as I recall.
Re: Engine squeal
« Reply #18 on: 04 June 2013, 16:35:22 »
95% thats tensioner pulley bearing mate ;)
As Kevin says, try it with belt off - but only for a very short while (that belt drives waterpump)
If its quiet then try removing and regreasing pulley.  I suspect though you will need a replacement.
Iain
Re: Engine squeal
« Reply #19 on: 04 June 2013, 17:20:33 »
I thought it was the tensioner to be honest. How hard is it to do the tensioner?
Re: Engine squeal
« Reply #20 on: 04 June 2013, 17:32:37 »
Get a new pulley only, not complete tensioner (~£25 on TC from memory)
10 minute job, drop aux belt off, undo 15mm bolt through pulley and remove pulley, fit new tighten bolt and refit belt - job done :y
Iain
Re: Engine squeal
« Reply #21 on: 04 June 2013, 17:37:31 »
Ach well easy and reasonable price so might as well do it
symes
  • oxford
    • R reg 940 volvo
Re: Engine squeal
« Reply #22 on: 04 June 2013, 20:56:57 »
reckon that it's your alternater-happens under load/hot-right - bearing going dry :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Engine squeal
« Reply #23 on: 04 June 2013, 21:14:05 »
Could be many things that's what's so annoying  :-\
Pulled the tensioner off today it was bone dry all greased up now and put a little more in the new pulley will go for a run again later.. Easier to take air filter box out to check/remove the tensioner  :y
Symes comment made me wish i'd checked mine also seen as i had pretty much everything off  :'( ;D
Re: Engine squeal
« Reply #24 on: 04 June 2013, 21:22:57 »
No need to remove air filter box to remove tensioner assembly ???
If pulley bearing dry just remove pulley - 1 bolt (15mm) - off in minutes ::)
symes
  • oxford
    • R reg 940 volvo
Re: Engine squeal
« Reply #25 on: 04 June 2013, 21:24:32 »
in january mine would squeal-when I got to work-20+ drive and same when got home-Everybody suggested tensioner so fitted new one I got as a back up-and noise still there-when on a run-spent a whole day belt off checking all pulleys-it was my alternator ??? so put my spare on-noise not come back---------yet :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Engine squeal
« Reply #26 on: 04 June 2013, 22:01:56 »
Aye, If you want to get the 2 large long bolts out holding the tensioner with a little more ease yes IMO :y
Re: Engine squeal
« Reply #27 on: 04 June 2013, 22:59:35 »
Correct tools for the job - easy ;)
Iain
Re: Engine squeal
« Reply #28 on: 04 June 2013, 23:22:25 »
Hmmm interesting thought on the alternator bearing,never heard one squeak before...a grinding yeah but not a squeak.
Im sure Irmscher Jim will have a spare alternator we could try :y
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: Engine squeal
« Reply #29 on: 04 June 2013, 23:24:18 »
Not everyone will though. Anyway's hope you get the noise sorted MonzaIain  :y
Pages: 1 [2] 3  All   Go Up
