Pages: 1 2 [3]  All   Go Down
Author Topic: Engine squeal  (Read 5311 times)
Iain
Re: Engine squeal
« Reply #30 on: 04 June 2013, 23:42:12 »
Cheers Mate,
I'll report back :y
Re: Engine squeal
« Reply #31 on: 05 June 2013, 15:38:38 »
Could be many things that's what's so annoying  :-\
Pulled the tensioner off today it was bone dry all greased up now and put a little more in the new pulley will go for a run again later.. Easier to take air filter box out to check/remove the tensioner  :y
Symes comment made me wish i'd checked mine also seen as i had pretty much everything off  :'( ;D
No need to remove air filter box to remove tensioner assembly ???
If pulley bearing dry just remove pulley - 1 bolt (15mm) - off in minutes ::)
Take it apart and grease it anyway , you wouldnt want it to shatter at 70mph like mine did .. what a mess  >:( ;D
Pages: 1 2 [3]  All   Go Up
Page created in 0.009 seconds with 14 queries.
