TerraClean - Any Good ?
Started by John-R, 04 June 2013, 15:27:57
John-R
I was watching an old episode of Wheeler Dealers last week - the one with the Jaguar XK8 and they give it to a viewer.
Ed - me old - China used a system called "TerraClean" to decarbonise the engine - he described it as "colonic irrigation for the engine"
He took some emission readings before and after and things improved drastically and the claim is that everything is hunky dory thereafter including engine response and economy.
I know Sam Burton posted his experiences and was impressed with the results on his DTi, just wondering if anyone had any experience with this on a petrol engine.
Sam mentioned about discounts if we could arrange a meet with interested members, but at 1 hour per car it could be a long meet ! !
//www.terraclean.co.uk/index.html
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
ffcgary1
I doubt that it would much to a modern engine to be honest, cleaner fuels and more efficent fuel burn and emissions mean that carbon build up would be ALMOST nil.
Save your money and do a full engine service, as that would help no end.
Gary.
Jaguar XJ6
Keith ABS
  Bloke on ABS is asking the same question as His LC puffs some oil smoke at idle if it idles for more than 15 mins. Apparently a lot of them do. he was wondering if it would work as his should have a bit more carbon in it due to the burnt oil. Apparently its £140
Keith B
ffcgary1
More likely to worn valve stem seals making it smoke, or even worn cylinder bores than carbon.
Redex was supposed to cure carbon build up as well but never saw any proof that it did, except cause vast amounts of smoke untill it burnt off.
Jaguar XJ6
Quote from: ffcgary1 on 04 June 2013, 20:11:32
Great fun wasn't it...... :D :D :y  Considered, as a kid, rigging up a washer pump, push button, not electric, to feed some Red X in on the move, James Bond style...... :D :D :D
Yep, or turbo oil seals on an LC.
I also think that a modern engine rarely has significant carbon build up when you strip it down, so there isn't much to clean that a good italian tune-up or a dose of injector cleaner wouldn't sort.
flyer 0712
Use Shell v.power...great stuff..for cleaning engine and a lot better performance  :y
Its a good job I'm a cinic by nature, as I actually find the bumpf for this quite believable.  :-\ But still refuse to use it. Must be snake oil, right?
The LC symptoms sound like stem seals, the 3.0 24V unit used to suffer the same (plus the seals will now be pretty old!)
As for the cleaner, anybody who has stripped a modern engine will note the lack of carbon build up. It still surprises me when I remove V6 or 4 pot heads as to how dam clean it all is. There is normaly a fine build up of soft stuff on the piston crowns but, this would re-appear in no time anyway after a clean.
Compare it to the carb engines of the 80's and earlier where the valves were encrusted in carbon the works.
Heard good and "bad" (by bad mean absolutey no change) reports of this - as said sounds believable - guess you pays your money and takes your chance.  Peronally wouldn't bother.
