Author Topic: EML Light  (Read 3817 times)
trueiron
  • SLady bitshorpe
EML Light
« on: 05 June 2013, 12:20:07 »
Hi all
Am back to being an omega owner again after a long break.  Just bought a 2002 2.2 CD with 68000 on the clock for a very low price
One thing - eml light is on and has been since the Head Gasket was changed according to owner.  Havent driven it yet but I would have thought its a simple case of resetting it
If so - anyone local to SLady bitshorpe with the right kit
Cheers
Impact Pete
  • Derby
    • Elite V6 2.6 estate
    • Custom Flightcase manufacture
Re: EML Light
« Reply #1 on: 05 June 2013, 13:24:09 »
Hi all
Cheers
Hi I thought an EML light went off on its own after around 20 clean engine starts, thats what happened to mine otherwise something else is still a problem ?
www.impactcls.co.uk - Flight Case Manufacture
trueiron
  • SLady bitshorpe
Re: EML Light
« Reply #2 on: 05 June 2013, 13:31:07 »
No - they have to be cleared
From what I can see - the owner (70 yr old lady) has always taken it to Vauxhall for work but refuses to pay £95 to get the light cleared
The car runs fine
Impact Pete
  • Derby
Re: EML Light
« Reply #3 on: 05 June 2013, 13:44:18 »
The car runs fine
Ok, mine cleared after  a few clean starts so hope you sort it.  :)
trueiron
  • SLady bitshorpe
Re: EML Light
« Reply #4 on: 05 June 2013, 14:27:29 »
Cheers
Re: EML Light
« Reply #5 on: 05 June 2013, 15:42:26 »
I can't think of an engine management fault that doesn't eventually clear the light once rectified, so expect there to be a fault on the engine somewhere.  ;)
The only system that needs a manual reset to turn off a fault light is the airbag.
trueiron
  • SLady bitshorpe
Re: EML Light
« Reply #6 on: 05 June 2013, 20:43:53 »
Ok mate
Will get the code read then see what it shows
Re: EML Light
« Reply #7 on: 05 June 2013, 20:51:45 »
No - they have to be cleared ....
wrong  ;) ;) The car can still a fault so the EML is still on.
As Kevin says, when the fault is fixed, the light will go out.  :y :y
symes
  • oxford
    • R reg 940 volvo
Re: EML Light
« Reply #8 on: 05 June 2013, 22:24:30 »
can you explain -my eml came on-read code-lamba sensor-put new one on and still eml on-disconnected battery and reconnected-eml went out-not come back on and no code---so far  :y
Re: EML Light
« Reply #9 on: 05 June 2013, 22:39:55 »
no  ;) ;)
symes
  • oxford
    • R reg 940 volvo
Re: EML Light
« Reply #10 on: 05 June 2013, 22:54:26 »
no  ;) ;)
never had that before-normally fix prob = eml off-but not this time it did'nt :o oh well - wait for next one ;D ;D
trueiron
  • SLady bitshorpe
Re: EML Light
« Reply #11 on: 08 June 2013, 16:01:19 »
Picked up and codes read - camshaft sensor.  No shocks there to be fair as replaced one on every Omega I have owned lol
Re: EML Light
« Reply #12 on: 08 June 2013, 16:24:23 »
Genuine only from VX ;)
Re: EML Light
« Reply #13 on: 08 June 2013, 16:53:04 »
Sure - resetting the codes reset the trims that were cocked due to a duff lamda.
(which is why if you suspect emissions related faults, look at the live data before clearing the codes)
  • Auckland
    • Mazda MPV
Re: EML Light
« Reply #14 on: 08 June 2013, 16:59:35 »
Silly question but.....
I thought/understood that the ECUs fitted to Omegas store the error codes in e2prom and that pulling the battery connection couldn't clear the codes :-\
Are fuel trims NOT stored in e2prom (stored in ram maybe) and forgotten if the battery is disconnected?
