Cheap code readers.
Started by Mr.OmegaMan, 05 June 2013, 17:34:06
Mr.OmegaMan
Looking to buy one for my 2002 2.2 / 2002 3.2
Was thinking along the lines of something like this   :-\
LINK
Looking for one cheap that will do all the essentials, clearing codes, eml, etc..
Thanks.
That ones good enough for basics Jay. Obviously won`t talk to other systems, ABS, autobox, alarm , SRS etc
Mr.OmegaMan
Quote from: RobG on 05 June 2013, 17:52:51
Would something like this (which has been mentioned in a few old threads be a better choice)
Link
Mr.OmegaMan
Could do with one that has live data to check this pedal trick code
P0130 - Indicates a fault on an O2 sensor which probably needs live data to see if it's a slow O2 sensor or something else causing a fault on that bank.
I was thinking i could delete all the codes presently on the car then see which ones come back then look further into them  :-\
Quote from: OmegaMan2.2 on 05 June 2013, 17:54:39
Link
Same as I use, live data as well
Mr.OmegaMan
Quote from: RobG on 05 June 2013, 18:03:24
Link
Is that the sort of price they are or is there a preferred website that sell them ?
Mr.OmegaMan
Mr.OmegaMan
Received today the Autel MS509
Only 2 stored codes on the 3.2 Elite bank 1 & 2 CATS below efficiency which is common for 3.2s i believe and no pending codes.
Cleared EML according to the device...
But it wouldn't clear a airbag light on my 2005 1.5TD Hyundai and doesn't work with the 2.2 Omega :-\
( if i put the live date info up and O2 live date can anyone check the results ? Trouble is the device wont connect to the laptop so will have to put the data in manually typing it  :o ;D )
Quote from: OmegaMan2.2 on 10 June 2013, 16:40:40
Won`t re-set SRS system.
Should work with the Desmond, did you have ignition on?
Quote from: OmegaMan2.2 on 10 June 2013, 16:40:40....
petrol or diseasal?  :-\ I've tried my Maxell on my diseasal Astra and didn't get anywhere
Mr.OmegaMan
Quote from: Andy B on 10 June 2013, 16:54:32
2.2i thought you'd remember I've been here for years lol  ;D..
Probably will be sending it back not before collecting the data mind get something out of this .
Will try uploading pictures/videos of the live data from the 3.2 readout  :y
Quote from: OmegaMan2.2 on 10 June 2013, 17:07:12...
They inject both petrol & diesel engines  ::)  ::)  ::)
