Author Topic: Is cam cover gasket same for 2 litre as 2.2?  (Read 1932 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 08 June 2013, 06:21:01 »
Y188NFA 2 .2 petrol manual
EML (engine picture) light on. It's due MOT, had car one year, thought I should change plugs; removed coil pack stick, found plug holes full of oil. When I bought the car last year I bought a cam cover gasket for 2 litre part number GM 55558349 but did not fit it. Will it fit the 2.2?
I know. I must do the breathers at the same time.
Re: Is cam cover gasket same for 2 litre as 2.2?
« Reply #1 on: 08 June 2013, 08:48:06 »
Question is, was the cam cover genuine GM part? For cam covers its critical its a genuine part  :y
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 08 June 2013, 09:11:46 »
Oh yes, genuine Vauxhall part, with genuine Vx 0 rings. It's a job I have done before on the 2 litres, but clearing the breathers on a 2.2 is all new to me. Everything seems undisturbed since it left the factory 12 years ago.
« Reply #3 on: 08 June 2013, 09:17:18 »
With genuine gasket and clean breathers they should last at least 100k or 10 years, mine lasted just 8 years, but first 80K was done by a monkey dealer  ::)
I made the guide here: http://www.omegaowners.com/forum/index.php?topic=90597.0
Trying to think what differences there could be, can't think of any.  :-\
Previously we have seen 2.0 heads on a 2.2 engine, there are few differences but don't think cam cover gasket wise there are anyway.  :-\
Need someone with to confirm part numbers  :y
andyc
  • Norfolk
« Reply #4 on: 08 June 2013, 09:21:14 »
Hi Terry
That part number 55558349 is listed as a 2.2 gaskets not a 2.0. The 2.0 is 90501944 and there is no supersession from onr to the other
Cheers
Andy
Thetford. Norfolk
« Reply #5 on: 08 June 2013, 11:09:27 »
Don`t forget the "O" rings & black sealant Terry
terry paget
    • 3 Astras 2 Vectra
« Reply #6 on: 08 June 2013, 16:06:33 »
Thanks for all the advice gentlemen. The camcover gasket is now replaced and the sealant is curing.
Two little slips in removing the throttle box. In unplugging the cam sensor a ring of insulation tape fell off. I tried to pick it up, missed,and it disappeared. I guess I had better recover that before I run the engine. I had trouble unplugging the lead from the throttle box. When I finally twigged I had to pull back the grey plastic bit I pulled it back and dropped it. Bother. Cannot find it. I do not think it does anything. The clip release is under it.
Looking on the bright side, the small breather hole was completely blocked. I eventually cleared it by poking a wire through it. That explains the gasket going, which in turn explains the misfire. The main breather tube I did remove, but it was not blocked. I have pulled it through with a rag now.
« Reply #7 on: 08 June 2013, 19:39:58 »
Good job  :y
Clean breathers really help those engines, they need all the horses they can muster  :)
Page created in 0.013 seconds with 14 queries.
