Author Topic: coolant level  (Read 1438 times)
grannon_mv6
  • Hull
    • 2002 2.6 mv6
coolant level
« on: 09 June 2013, 03:30:56 »
Hi all, i keep getting a warning message up on the dash saying coolant level. I have checked the level and all is fine.
Any ideas why im getting this?
Drive it like you stole it
Re: coolant level
« Reply #1 on: 09 June 2013, 03:51:17 »
The sender has either failed (float stuck down) or fallen apart (a 10p sized washer and a golf ball sized float bobbing around in the header tank).
Former is a new tank job, £35 ish. Latter is repairable with care and a soldering iron :y
Re: coolant level
« Reply #2 on: 09 June 2013, 08:35:40 »
Benefit of a new coolant bottle is they are clear and look so much better  :)  :y
Re: coolant level
« Reply #3 on: 09 June 2013, 10:08:55 »
Or the reed switch is shagged, which is surprisingly common - trouble is, nigh on impossible to remove without snapping the board (I've done loads, and still only have a 50% success rate  :-[
New bottle is the easy fix.
Re: coolant level
« Reply #4 on: 09 June 2013, 16:34:46 »
Check sensor plug still connected (under the bottle)  ;)
grannon_mv6
  • Hull
    • 2002 2.6 mv6
Re: coolant level
« Reply #5 on: 10 June 2013, 00:47:43 »
Cheers everyone i will check it all out after my night shift
