Author Topic: Peugeot 206 Misfiring  (Read 18957 times)
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« on: 09 June 2013, 13:35:19 »
Yeh Yeh, I know, it's French.  ::) ::)
Daughters '53 plate' Peugeot 206 1.4 8V has had an intermittent fault lately but it's just decided to be a permanent fault. Key out and re-start sometimes cleared it but doesn't now.
The symptoms are:
1. Loss of power but the engine will still run and idle, albeit very lumpy and sounds like it's hunting.
2. EML flashes with audible beeping. (Now permanently on and beeping)
3. Starts first time but is reluctant to rev. Very shaky when revved, like it's mis-firing. Struggles to get to 50mph so I have ruled out ICV.  :-\
Very basic checks carried out so far:
1. Unplugged MAP/MAF sensor resulted in no change.
2. Unplugged the injectors one by one with engine running. Injector No.4 had the least impact on idle speed, but not sure how conclusive that is as it seemed to vary.  ::)  :)
Thought I'd put out a feeler on here to you knowledgeable folks first before getting the codes read and then looking at sensors, coil packs etc. Shame they can't be 'blink tested'.  ::)
I've probably introduced a few more codes myself by removing plugs so will get it cleared first.  :y
Cheers for any input ..............................apart from 'its French' insults:y ;D ;D
Re: Peugeot 206 Misfiring
« Reply #1 on: 09 June 2013, 13:45:11 »
Errr!  :-\ That's all I can think of  ::)  ::)  ::)
He says, whose daughter's car is Italian!  ;D  ;D  ;D
YZ250
« Reply #2 on: 09 June 2013, 13:54:50 »
It had to happen so you may as well be the first.  ;D
« Reply #3 on: 09 June 2013, 13:56:30 »
we're THAT predictable  ::)  ::)  ;D  ;D  ;D
Can you beg or borrow a code reader of some sort? My Maxiscan read faults on my wife's Smart & s-in-l's Fiat.
May cam or crank sensor  :-\  :-\ :-\
« Last Edit: 09 June 2013, 13:58:51 by Andy B »
YZ250
« Reply #4 on: 09 June 2013, 14:22:13 »
Will pop it over to my mates tomorrow to see if his snap-on modus will read it.  :y
Bless her, the car has not let her down in over five years in her ownership and just when she is about to pick up the keys to her first house, and needs every penny, it starts playing up. The law of sod I believe it's called.  :(
« Reply #5 on: 09 June 2013, 16:28:01 »
French  >:( Just got over the nightmare 106  :( ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 09 June 2013, 16:57:29 »
Got one at work with similar symptoms, runs well from cold then develops misfire,I suspected coil pack but turned out to be injector number 1,so either injector itself or wiring harness or at worst case drivers in ecu,luckily I have a working scrapper  to swap parts from
other rides
YZ250
« Reply #7 on: 09 June 2013, 17:14:46 »
Where've you been, I've been waiting for you.  ;D ;D Thanks Henry, much appreciated.  :y Injector 4 ( I think its 4 ) had the least impact but will get the codes read tomorrow and we'll see what it throws up. Is injector 4 the one next to the cambelt.  :-\
« Reply #8 on: 09 June 2013, 17:46:13 »
Number 1 is at the front next to the cambelt, number 4 being the gearbox end :y
Notable exceptions being VAG diesel Vs which have the timing gear at the gearbox end ::)
henryd
  • west cornwall
« Reply #9 on: 09 June 2013, 17:47:26 »
according to autodata number 1 on that engine is gearbox end ???
other rides
« Reply #10 on: 10 June 2013, 08:46:10 »
Well it is French ::)
henryd
  • west cornwall
« Reply #11 on: 10 June 2013, 09:12:09 »
Aye,god knows why the frogs do everything ass backwards ::)
other rides
« Reply #12 on: 10 June 2013, 09:59:32 »
Ah that's easy :y
They do because they can. It matters not what or how, or even on the outcome. Being French is justification enough ;D
YZ250
« Reply #13 on: 10 June 2013, 11:30:40 »
Codes cleared. Codes re-read and code showing Injector fault, but not which one, came up. Me thinks I'll start with No.4 as this made the least difference when removed. I hope it is an injector as they are not cheap to buy for elimination purposes.  :o :o Then have to check the wiring if that fails.  :-\
Got moaned at for introducing additional codes by fiddling.  ;D ;D
hoody
  • Scotland
« Reply #14 on: 10 June 2013, 11:41:45 »
Did these not have little washers/seals which the injectors sat in/on which used to erode and cause problems,i remember my mate having to get them replaced,cheaper than injectors.
