Author Topic: need mechanic  (Read 3708 times)
gray73
    • omega cdx
need mechanic
« on: 09 June 2013, 17:19:23 »
hi, can any1 put me in touch with some1 who can do the rocker cover gaskets and inlet manifold gasket on my 2.5 v6, im in blackburn lancashire.
thnx
graham
« Last Edit: 09 June 2013, 17:26:31 by gray73 »
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: need mechanic
« Reply #1 on: 11 June 2013, 17:42:31 »
Are you sure you need to change your inlet manifold gasket? I have not changed one in years.
kluku5
Re: need mechanic
« Reply #2 on: 11 June 2013, 17:54:53 »
Maybe he wants to change it because you have to remove the inlet to do rocker cover gaskets?
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: need mechanic
« Reply #3 on: 11 June 2013, 19:23:23 »
hi,
inlet manifold gasket  ???
there are 6 rubber rings between plenum and inlets and then red rubber gaskets between inlets and ''sandwich plate''. is it these you want replacing?  :-\
RIP Paul Lovejoy
Re: need mechanic
« Reply #4 on: 11 June 2013, 19:29:53 »
They shouldn't need replacing even if the manifold has been off and on numerous times.
Re: need mechanic
« Reply #5 on: 11 June 2013, 21:30:06 »
Agreed, always reused existing ones without any issues :y
terry paget
    • 3 Astras 2 Vectra
Re: need mechanic
« Reply #6 on: 11 June 2013, 23:05:17 »
Hi Graham, what sympton makes you think you need to change your inlet manifold gasket?
 My 2.5 V6 spits a bit on start up and I used to think it was exhaust manifold gasket. But having had two 2 litre Omegas develop cracks in their exhaust manifolds, I fear I have a crack in the right hand exhaust manifold. It seems to be a failing of cast iron exhaust manifolds.
gray73
    • omega cdx
Re: need mechanic
« Reply #7 on: 15 June 2013, 18:22:29 »
hi, was just changing it as the inlet had to come off for the rocker gaskets, which are now done, im still having an idle issue the engine seems to be moody sometimes idles nice and sometimes it dips away and idles ruff. the car has been fully serviced with new coil pack and leads, im out of ideas,,, any suggestions?
cheerz
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: need mechanic
« Reply #8 on: 15 June 2013, 19:00:55 »
Give Darth Groomer, Bum Improver a shout  :y
Don't be scared, he can be gentle sometimes    :-X :-X ;D ;D ;D
Linky type thing  :y
http://www.omegaowners.com/forum/index.php?action=profile;u=12562
Webby the Bear
  • Northampton
Re: need mechanic
« Reply #9 on: 15 June 2013, 20:57:03 »
no need to replace inlet gaskets  :y
RIP Paul Lovejoy
Re: need mechanic
« Reply #10 on: 15 June 2013, 22:16:37 »
cheerz
Clean ICV, clean breathers if not done with cam cover change ;)
Webby the Bear
  • Northampton
Re: need mechanic
« Reply #11 on: 15 June 2013, 22:56:22 »
cheerz
What he said  ;D if issue still unresolved look for vac leaks and small exhaust leaks.
RIP Paul Lovejoy
noel
  • frome somerset
  • i feel the need for speed
    • 02 omega 2.6 v6 cdx auto
Re: need mechanic
« Reply #12 on: 16 June 2013, 09:48:38 »
might also be worth giving the throttle body a good clean if doing breathers etc  :y
gray73
    • omega cdx
Re: need mechanic
« Reply #13 on: 28 June 2013, 16:21:16 »
hi guys, ive replaced the track rods and the wishbones with aftermarket ones, had it tracked. the car dosnt seem to drive right , seems a ruff ride, anything to do with non genuine parts?
Re: need mechanic
« Reply #14 on: 28 June 2013, 16:31:08 »
Those items should not affect ride, thats set by the springs/shocks. Omega does need full geometry though, rather than just a track in my experiance  :y
Page created in 0.164 seconds with 16 queries.
