Author Topic: Plenum bolts  (Read 2145 times)
jonny2112
  • Bangor NI
    • 2.6 Elite
Plenum bolts
« on: 10 June 2013, 22:19:31 »
Are plenum bolts unique to vx? Or are they a standard size and thread that could be obtained elsewhere?
Just wondering if a longer bolt could be sourced and still fit properly?
Tia  :y
Re: Plenum bolts
« Reply #1 on: 10 June 2013, 22:20:43 »
Tia  :y
Why?  Guess they are standard metric thread though ;)
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: Plenum bolts
« Reply #2 on: 10 June 2013, 22:25:04 »
i think they are m8 thread. if you have knackerd the thread,in the intake, just run a tap down the thread.should restore it,as its only alloy.
« Last Edit: 10 June 2013, 22:27:02 by biggriffin »
Hoof'land storeman.
Re: Plenum bolts
« Reply #3 on: 10 June 2013, 22:28:38 »
Or you may need a replacement inlet manifold if thread really goosed, or maybe consider helicoiling ;)
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: Plenum bolts
« Reply #4 on: 10 June 2013, 22:32:01 »
Thanks for that.
Theres no damage caused or anything, but it might be a useful way of attaching a bracket to the plenum .......  ::)
I'll try m8 and see how it goes when the time comes  :y
biggriffin
Re: Plenum bolts
« Reply #5 on: 10 June 2013, 22:37:31 »
why replace or helicoil, when just go up a size to m10,if theres enough material.
Hoof'land storeman.
Re: Plenum bolts
« Reply #6 on: 11 June 2013, 15:23:53 »
Thats true, assume sufficient clearance in the plenum itself for bolt and head?
symes
  • oxford
    • R reg 940 volvo
Re: Plenum bolts
« Reply #7 on: 11 June 2013, 22:14:51 »
stripped one on mine-drilled/heli coiled in situ - easy really blew filings away with airline :y
