2006 Audi A3 1.9 TDI 105 Judder/Misfire?
Started by Del Boy, 12 June 2013, 17:16:18
I've read about the injector thing, I think that's what it is, although I still haven't changed the fuel filter. I like it though, nice car  :y.
Quote from: ex taxi al on 28 June 2013, 15:11:31
DMF on my Altea, same engine/box  gave up at 65k ::) similar symptoms iirc :-\
Seems you could well be spot on :(. Clutch started slipping earlier under heavyish throttle, horrible chattering noise after giving it some which got worse when putting the clutch in. Been nursing it back from where I was and it's given no trouble. 'Quality German Engineering'  ::) ;D.
Quote from: Del Boy on 30 June 2013, 02:27:40
Bit of an oxymoron there ;D
Be wary of the clutch slave cylinder. Mine failed shortly after the dmf and clutch were changed ::) the only positives when the dmf failed on the Altea, was that it was replaced under warranty, my only cost being the clutch parts 8) clutch was changed out of convenience rather than failure though :-\
