2006 Audi A3 1.9 TDI 105 Judder/Misfire?
Started by Del Boy, 12 June 2013, 17:16:18
Got a 2006 Audi A3 at the minute, VAG 1.9 TDI 105, when under load in 2nd, 3rd and 4th and you plant your foot right down you get a shudder vibration (noticeable by everyone) as the turbo kicks in, and in 5th the whole thing shakes violently as if its misfiring, if you accelerate higher up the Rev range however it's fine? This only happens if you go under full load, ease the power on and it's ok. Any ideas?
Also anyone know the oil capacity for these engines?
henryd
They hold around 4lt Del,which engine?,1.9 or 2.0 16v,1.9's(pD lump) suffer with the injector loom which enters the head going brittle and breaking up,you need a reader on it to make sure though as it could be summit else :y
other rides
hoody
Quote from: henryd on 12 June 2013, 18:31:26
1.9 TDI 105 :y. I'll have a check, will get the reader on it too. It's a strange one, haven't heard of it before really.
Quote from: hoody on 12 June 2013, 18:37:09
Fuel filter??
That's a thought I was having, I'll order one in the morning. Giving it a full service before it goes anyway :).
henryd
other rides
pscocoa
Quote from: Del Boy on 12 June 2013, 17:16:18
My son had a 2007 A3 1.9tdi and the gearbox problem was more a hesitation issue then a shudder when it picked up - it was off the road weeks while they tinkered with software - ended up with new gearbox. On Audi forums there seemed to be a certain resignation that this is a "feature" of this model. We did not accept that conclusion.
Quote from: pscocoa on 12 June 2013, 22:11:28
Was his Auto or Manual? Certainly doesn't feel gearbox to me, and I hope it isn't.
pscocoa
Doing the service, got the fuel filter out, looks clogged right up which could maybe point to my problem, however they have sent me the wrong fuel filter  >:(.
DMF on my Altea, same engine/box  gave up at 65k ::) similar symptoms iirc :-\
Quote from: ex taxi al on 28 June 2013, 15:11:31
It crossed my mine, and then a friend mentioned it, I sincerely hope it isn't, I do think it is injector related to be honest, but have got to pop and get the new fuel filter shortly, so will see if that helps. It's had some TLC today (Oil, oil filter, air filter, new top mounts, new anti-roll bars, new CV boot) so whatever the fix it best be simple  ;D.
symes
from your problem -I would say fuel filter :y
Omegatoy
oops electronic injectors known for faults on these motors!!  ::)
