Author Topic: Omega Key Programming  (Read 1568 times)
John-R
  • Liverpool
    • 2003 2.6 V6 CD
« on: 12 June 2013, 19:24:13 »
Got 2 keys with the car but have only ever used 1. The second key is already cut but I found out the other week that it's not programmed.
The first key is wearing away on the buttons.
I read somewhere that the local locksmith will only clone the key and not programme it properly using Tech 2. What is the difference in practical terms ?
Locksmith £45 vs Tech 2 £??. Is there a Tech 2 guy near me (Liverpool)
Also can I buy a replacement key and simply swap the already cut part of my original key and swap the internal gubbins so I then have 2 good keys ?
Thanks
You can pick your friends and you can pick your nose . . but you can't pick your friends nose !
Re: Omega Key Programming
« Reply #1 on: 12 June 2013, 20:51:19 »
Yeah, if you swap your working transponder and electronics part of the fob, that'll work
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #2 on: 12 June 2013, 21:17:10 »
You can buy new key case's on ebay for about £5.00.
Hoof'land storeman.
« Reply #3 on: 12 June 2013, 21:18:47 »
The ebay 3 button ones are quite poor to be host - too hard rubber.
