Author Topic: Immobaliser sensor removal  (Read 2219 times)
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
« on: 12 June 2013, 22:52:48 »
The ring around the ignition barrel - how the heck do you get it off - cannot see how
Help pls
P
Re: Immobaliser sensor removal
« Reply #1 on: 12 June 2013, 23:53:16 »
Sorry Phil .......... but you're not alone, I've looked in the past & chose not to bother  ???
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #2 on: 12 June 2013, 23:56:08 »
Help pls
P
Why
« Reply #3 on: 12 June 2013, 23:57:13 »
There's a definite knack to it :-\
Sadly it's been a while, so memory a bit vague, but think you need to remove the barrel first :-\
SIR Philbutt
    • PJB Home Services
« Reply #4 on: 13 June 2013, 02:07:22 »
Help pls
P
Why
Stripping old car and going to match to ecu and chips for sale
SIR Philbutt
    • PJB Home Services
« Reply #5 on: 13 June 2013, 02:08:23 »
That was going to be my next way to try - ta  :y
SIR Philbutt
    • PJB Home Services
« Reply #6 on: 13 June 2013, 02:09:41 »
When I've done it will pass on  ;)
« Reply #7 on: 13 June 2013, 10:47:38 »
I think there's a tab accessible from inside the barrel housing :-\ got a new barrel to fit to mine so can investigate further, but won't be before next week...
« Reply #8 on: 13 June 2013, 12:09:28 »
Help pls
P
Everyone I`ve removed just a sharp pull and it`s off
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #9 on: 13 June 2013, 12:41:59 »
Help pls
P
Snap  :y
Or a little bit of persuasion with a large flat blade screwdriver ;)
Page created in 0.063 seconds with 16 queries.
