Silencer Clamp
Started by omega3000, 17 June 2013, 16:11:30
On Vectra B , the silencer clamp has rotted away but can you buy a clamp that comes in 2 pieces as it looks like a one piece clamp thats on it put on before the flare  :-\
I think the only thin that will join the silencer to the pipe will be a V clamp or something rob  :-\
Something like this http://www.ebay.co.uk/itm/Universal-2-5-Heavy-Duty-Stainless-V-Band-Clamp-Exhaust-Turbo-Downpipe-/260886667071?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3cbe0e9f3f  :-\
Has to be a V for the lip on the silencer unless i flatten the lip and use one like in your link  :-\ :-\
In the picture the clamp you see has rotted away .. so need some kind of replacement  :(
symes
must be my eyes mate-has formed flange rotted away?
Quote from: symes on 17 June 2013, 21:23:32
Thats just a picture of one thats ok mate not actually mine  ;) As you see the clamp cannot be taken off or a new one put on unless i flatten or cut off the lip on the pipe  :-\
symes
oh yes you can ;) ;) cut pipe-fit flange-weld pipe up ;)--see what happens when a hotrodder gets on here :y
Quote from: symes on 17 June 2013, 21:32:44
That would do it but dont have a welder mate  ;D + not sure if the flanges are available separate  :-\
symes
check here mate-http://www.popbrowns.co.uk/ might help--or scrappy? might be worth a mooch?
I think the only solution is to take the box off and flatten out the lip on the pipe then fit a straight joining piece if nothing else becomes available  :-\
Or make a bracket up so that bolts from other end pull the 2 parts together , ill work something out .. always do in the end  :y
symes
before you start bashing---think a minute-if you get flange off-then what??
Quote from: symes on 17 June 2013, 21:54:52
Flange is hanging on by a thread mate , just rust so i just wrapped it in a exhaust bandage and paste . A screwdriver would prize it off its that brittle  :(
What you described is out there somewhere
Quote from: Andy H on 17 June 2013, 22:02:51
That i think would do it  :-\
Where did you find that picture andy  :y
symes
Walker Exhaust 35455 Hardware-Flange-Repair Kit
