Author Topic: Project - The Test Drive!  (Read 3200 times)
« on: 18 May 2008, 23:20:40 »
Fired up the project 2.0 this morning - started first time and sounded ok at idle.
Took it for a spin - OK for a bit, then an awful misfire to the point it nearly wasn't drivable, it wouldn't take any load. Stopped at halfrauds - looked at HT leads again - indeed they were knackered. So it needed leads.
Halfords wanted £29 for a set of their own 2.0 leads.. hmm...expensive, me thinks, on a £100 car! So markie and I start opening other boxes... ::) ... and find a set of leads that look very suitable (same connector at DIS end, and good insulator on the plug and decent length) - £10.99. Not sure what car they were meant for, but they did the job nicely on the Meega - so fitted them, happy in the knowledge I'd just saved another £20 on the project (Am I a Pikey or
what?) ;D
However - Once fitted the misfire went right away.  :D
Was initially a bit top end rattly for a few miles (still is a tad) so I drained out the (tesco) oil that came with the car, popped on a new filter and filled with genuine GM 10 40 oil. A lot quieter, so a few frequent changes will cure that.
Coolant temp is stable, got rid of one airlock and pressure doesn't seem OTT anymore.
Autobox - thank the lord it was just crying out for a bit (lot!) of fluid, and is now operating totally normally now it's had a top up!
I drove 125 miles in her today, and didn't miss a beat, or lose any fluid, so I think it's project sucess. Over the course of that trip I got exactly 35mpg driving carefully, all dual carriageway or A roads. Not bad, but I would have expected closer to 40mpg under such conditions (I'd easily get that from other 2.0 Omega's I've owned). It also feels a little down on power even for a 4 pot, and The EML is still on. Seems  the lambda hasn't sorted itself out, so I'd imagine this is accounting for loss of power and MPG.
I'll get on ebay and get one, then we should be good to go. :D
Re: Project - The Test Drive!
« Reply #1 on: 18 May 2008, 23:22:13 »
Ah, yes, I had to do a repair on the sump too. When I pulled out the plug - a lot of thread followed it  :-?
    • 530D M Sport, 330i Coupe
« Reply #2 on: 18 May 2008, 23:36:43 »
Good job James.
I'm sure the sump plug didn't cause you too many problems.... you did after all pioneer the 'unstrippable' sump plug!
« Last Edit: 18 May 2008, 23:37:00 by VXL_V6 »
« Reply #3 on: 18 May 2008, 23:57:46 »
It bloody worked, too ;D
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #4 on: 19 May 2008, 00:06:11 »
nice work mate :y
what is this unstrippable sump plug? must have been before my time :-?
« Reply #5 on: 19 May 2008, 00:24:14 »
nice work mate :y
A VERY crude invention of mine ::)
Still want a hand with your cambelt sometime ? :)
« Reply #6 on: 19 May 2008, 10:55:55 »
now you have had some practice fancy comming over to mine and doing another 2.0?  ::)  ;D ;D
« Reply #7 on: 19 May 2008, 10:57:34 »
LOL, I knew that was coming ;D.  Have you done a compression test yet?
« Reply #8 on: 19 May 2008, 11:28:30 »
So did I!
« Reply #9 on: 19 May 2008, 13:43:18 »
Lol, me three!
What are the exact symptoms Tunnie - any smell of petrol in header tank?
« Reply #10 on: 19 May 2008, 13:46:26 »
Lol, me three!
I'm undecided if it smells of petrol.  Initially I thought it did, but then I thought it smelt more solvent like (and I promise I hadn't been on the glue earlier ;D), hence why I asked Tunnie to do a compression test.
« Reply #11 on: 19 May 2008, 14:03:36 »
Lol, me three!
For the little it costs, on a project 2.0 you may as well go the whole hog and replace all the top end gaskets, seals anyway... if it's a keeper.
« Reply #12 on: 19 May 2008, 14:05:53 »
Lol, me three!
He has to do something, as the tinker doesn't even start.  I'd also paperclip it on the offchance there is a sensor problem, and the coolant loss is unrelated.
« Reply #13 on: 19 May 2008, 14:08:09 »
Lol, me three!
Doesn't start! Oh dear.
I'd say paperclip it first, and if no codes - get the comp. tester out!
« Reply #14 on: 19 May 2008, 14:09:38 »
Lol, me three!
This is Tunnie we are speaking about.  He's probably changing the stereo first, or whatever you youngsters think are the priorities nowadays ;D
