CD with no sunroof
Started by omegod, 18 June 2013, 13:34:35
omegod
Came across one and for some reason thought it was a bit odd, I don't recall seeing an omega with no sunroof other than plod ones?
Only standard on CDX & Elite
bored bigyin54
Quote from: omegod on 18 June 2013, 13:34:35
mine is one without a sunroof . i like it without a sunroof :y :y
Mr.OmegaMan
As has been said in the past there isn't really much point in a sunroof with a car with air-con.
Mine has a little flaking paint on the outer alloy rim  :-\
CDX/Elite came with them standard.  :y
Quote from: OmegaMan2.2 on 18 June 2013, 16:05:37
Agreed.  Never used mine :D ;)
martin42
mine doesnt have 1,ohh wait i can drop the roof and go topless  ;D ;D ;D ;D
I find the sunroof rather pointless to be honest, its also a tad loud, find myself shutting the blind.
But as above only standard on CDX & Elite, all other spec it was optional extra  :y
plym ian
Sunroofs only function is to burn the top of your bonce on a hot sunny day, as I found out last year ;D
Standard across all PFL/MFL, except GLS with A/C option picked.
Only on CDX/Elite on FL, because we all know FL are inferior.
Webby the Bear
I have a CD with no SR.
I'd like one but not really that fussed.
RIP Paul Lovejoy
Quote from: Webby the Bear on 18 June 2013, 18:38:38
Inferior FL :P
Find mine quite useful if I open it up for a few mins to let the heat out of the car when it's been parked all day. Aircon doesn't have to work so hard then!
I love my sunroof. AC alone would do my head in.
bored bigyin54
Quote from: TheBoy on 18 June 2013, 19:52:24
never use AC .that's why i got windows  :y :y
I_want_an_Omega
Quote from: TheBoy on 18 June 2013, 18:35:13
Not 100% true. I had a CD with no SR and recall the spec was changed at some point due to marketing reasons - at the same time as on the Vec B with many cars having SR at launch and then then becoming an option. Vx did this a couple of times in the '90s using it as an opportunity to lower the price as a SR is quite an expensive item to add in cost-wise ....
