Ford Fusion brake grind update
Started by Webby the Bear, 18 June 2013, 15:45:12
martin42
how come your post count hasnt been culled ?????
Webby the Bear
cheers mate  :y
hahaha its cos i haven't mentioned the thing that shalt not be named  ;D ;D ;D
RIP Paul Lovejoy
martin42
Webby the Bear
that's just made me think of something.....
at the front both inner pads that attach to the calipers have tat 4 pronged clip thingy...... BOTH outer pads don't. but it says in the Haynes that there should be a clip on the outer ones too.
could this be the reason for the grinding i wonder?
RIP Paul Lovejoy
Webby the Bear
RIP Paul Lovejoy
martin42
no ignore haynes  ;D ;D
what is the taboo thing your not allowed to mention,you can tell me and i wont tell any1  :-X :-X
Webby the Bear
Quote from: magic tree 42 on 18 June 2013, 17:51:54
hahahahaha i'll pm you  ;D ;D ;D ;D ;D
RIP Paul Lovejoy
Webby the Bear
soz to keep on about this stooped ford  ::)
my impact wrench has a torque of 450nm. does that mean it will undo any bolt/nut that's done up to that torque? the axle nuts on the rear are done up to 235nm so i'm hoping this will be childs play for my gun but just want to check  :y
RIP Paul Lovejoy
henryd
In theory yes it should but sometimes what it says on the label ain't quite the same as what it does ::) ;)
other rides
Webby the Bear
Quote from: henryd on 18 June 2013, 19:39:02
lol understood thanks mate.
it zaps the wheel bolts off done to 110 with no drama at all  :y
RIP Paul Lovejoy
martin42
i used my 24" breaker bar and that undid mine no problem :y
Webby the Bear
Quote from: magic tree 42 on 18 June 2013, 20:55:28
im a proper lazy b...... though  ;D ;D ;D
RIP Paul Lovejoy
