Ford Fusion brake grind update
Started by Webby the Bear, 18 June 2013, 15:45:12
Webby the Bear
Hi guys,
As per my recent thread regarding my Ford Fusion I lubed up the pads nicely, cleaned off the crap and that didn't solve my brake grind on initial movement with brakes half applied.
SO.
I went out and did some diagnosis work today. mum moved the car while I listened and it seemed to me that it was defo coming from the front. checked all suspension components. all tight as a nuns crutch. good! but i'm still thinking i need to replace the pads and discs.
ANYWAY, got to the rear and press down on the rear of the car...... grinding/clunking noise similar to the aforementioned noise ??? ??? ???
anyway had the rear up in the air and like the front I checked all rear suspension components. no play whatsoever. good!
i took the car off the stands and pushed it up and down again... clunking, grinding etc. really quite bad. took the handbrake off and sound goes away  ::)
i'm thinking i need to get the drum off and see whats what.
do y'all concur? :)
RIP Paul Lovejoy
Not sure what the rear brake setup on those is like - if it's 'drum in disc' or drum then it sounds like the handbrake shoes are making insufficient contact and not locking the wheels completely; as you bounce the car you'll rotate the wheel very slightly and the shoes tend to grind on whatever rust is inside the drum on the face.. the M3 did exactly that until I did the rear discs ('drum in disc' the same as the Omega)..
Webby the Bear
Quote from: aaronjb on 18 June 2013, 15:52:04
Exactly what is happening Aaron  :y no discs at the back... just the drums.
you reckon i should just replace them or do a bit of adjusting with the star wheel (theres a little access hole to the star adjuster through the back of the hub :))
RIP Paul Lovejoy
I'd pull the drum off and inspect the shoes and the inner drum surface - you might be able to rescue them with liberal application of a wire brush on the drum and possibly a little emery paper on the shoes.. unless the shoes look like the ones in the M3; like the surface of an LP ;D
Webby the Bear
will do cheers mate.
is it possible that they need adjusting also? wondering if theyre too loose or too tight  :-\
RIP Paul Lovejoy
martin42
i think it might be best to change the shoes,as it sounds like they are wearing very low,and also check the torque setting,if its the same as the fiesta,puma,escort,its 230lb ft  :y
which brings me nicely on to torque wrench,lol,if your over this way sometime,can i borrow it again if it goes up to 230 as i need to check my rear bearings after i changed them,also it might be worth changing the bearings aswell if removing the drum  :y :y
Quote from: magic tree 42 on 18 June 2013, 17:11:00
I think we need a torque wrench party as i would also like to borrow it steve  ::)
Webby the Bear
Yeah course you can boys :) just checked and it goes up to 200nm.... no idea what the foot pound equivalent is  :-\
i'll more than likely be over kettering next week. is that cool?
i'm gutted cos the axle nut on the rears needs to go to 235nm  ::) ::) ::)
RIP Paul Lovejoy
martin42
sorry it was 230 nm,i can change the rear bearings within 5 mins  :y
Webby the Bear
sadly mate only goes to 200nm but of course youre more than welcome to use it. you want me to pop it over still next week?
if so ill be near the warren pub... is it easy to get to yours from there
RIP Paul Lovejoy
martin42
that will be fine mate,let me know what evening and il have it already just to torque up when you get here :y
Webby the Bear
no worries mate  :y
ill get the fronts done this wek too. hopefully that will sort out the front grinding.... then the drums to do  ::)
you know those stupid clips the secure the inner pad to the caliper.... can i discard these or do they have to be used? i keep the anti rattle clip though  :y
RIP Paul Lovejoy
martin42
you need to keep them,im working sat morning,can call in after work if that helps  :y
Webby the Bear
thanks mate but not to worry.... ive had them off already and theyre pretty easy.
will i need to reuse the old ones or are they part of the pad?
RIP Paul Lovejoy
martin42
