Author Topic: oil pressure light on when idling hot  (Read 1670 times)
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
« on: 19 June 2013, 10:55:44 »
Y188NFA 2.2 petrol manual 84333 miles on clock
Oil light comes on at idle when hot. Goes out when revved. Worrying. I have had this before on older cars, usually sign of worn oil pump and/or bearings. Not on a young Omega, surely? Do the sensors play up?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: oil pressure light on when idling hot
« Reply #1 on: 19 June 2013, 10:59:57 »
For the sake of a few quid its probably worth replacing the sensor first but it could be the oil strainer in the sump partially blocked or of course the pump failing as a worst case scenario :-\
other rides
terry paget
    • 3 Astras 2 Vectra
« Reply #2 on: 19 June 2013, 12:02:06 »
Thanks, Henryd. Do you know where the oil pressure sensor is?
henryd
  • west cornwall
« Reply #3 on: 19 June 2013, 12:06:23 »
Not a clue Terry :-\,one of the 4 potters will be along shortly I expect(where is RobG with a picture when he's needed ::)) ;D
other rides
terry paget
    • 3 Astras 2 Vectra
« Reply #4 on: 19 June 2013, 17:12:55 »
Haynes does mention it, gives the job 2 spanners and no pictures. It's somewhere at the front of the engine, apparently screwed into the rear of the oil pump housing on 2 litre engines. A picture would be appreciated!
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #5 on: 19 June 2013, 17:36:54 »
It could be the oil pressure relief valve,needs a clean.
Hoof'land storeman.
terry paget
    • 3 Astras 2 Vectra
« Reply #6 on: 19 June 2013, 17:42:45 »
Agreed. Haynes does not mention the oil pressure relief valve in the index. Does anyone know where it is? Is there a how to guide?
