Author Topic: track rod ends  (Read 3566 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
track rod ends
« on: 19 June 2013, 13:01:13 »
Hi All,just a quick question.Had the drivers side trackrod end changed today.Do i need to have the tracking done,at a garage or can it be done manualy.Kind Regards Dean :yFor got to add my mechanic has only removed,the first screw in bit.Not the whole arm,is this ok :-\
« Last Edit: 19 June 2013, 13:11:47 by moggy »
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: track rod ends
« Reply #1 on: 19 June 2013, 13:23:58 »
my understanding is that you should have an alignment done ad I personally would. however if he counted the threads on the inner tie rod and snugged the lock nut/outer track rod accordingly it wil be close to bang on.
but you should imo  :y
RIP Paul Lovejoy
Re: track rod ends
« Reply #2 on: 19 June 2013, 15:30:46 »
My understanding is you should replace TRE's in pairs  ;)
moggy
  • hartlepool
Re: track rod ends
« Reply #3 on: 19 June 2013, 16:35:22 »
Thanks webby,managed to get it done just now.At a local garage.Regards Dean :y
moggy
  • hartlepool
Re: track rod ends
« Reply #4 on: 19 June 2013, 16:38:02 »
Hi emd,you are probably right.But its to late now as my mechanic,has gone to another job.I will just have to see how it goes.Regards dean :y
terry paget
  • Midsomer Norton Somerset
    • 3 Astras 2 Vectra
Re: track rod ends
« Reply #5 on: 19 June 2013, 20:18:57 »
I see no reason to change track rods in pairs, so long as the old track rod is freely adjustable. If it is not, I would remove it from the car and free it.
Re: track rod ends
« Reply #6 on: 19 June 2013, 21:11:35 »
Cobblers, young jedi ;)
Re: track rod ends
« Reply #7 on: 19 June 2013, 21:11:48 »
Agreed
chrisgixer
Re: track rod ends
« Reply #8 on: 19 June 2013, 22:59:16 »
Having spent too much time disagreeing with Terry, I would like to make it known that I fully agree with him this time. No need to change both, but keep a close eye on the other one, if it has equal miles on it. ;)
Strictly speaking....Just set the tracking! ...but take it somewhere with accurate equipment. Which usually means a hawk eye laser liner. Its hard enough to get the steering straight on these without the chalk and a piece of string experts adding their tuppence worth.
Re: track rod ends
« Reply #9 on: 19 June 2013, 23:31:38 »
Agreed no need to change TREs in pairs - although if one has gone other may not be too long behind it!
Whilst counting the threads gives it an approx degree of accuracy only, it at least allows you to drive as far as your friendly geo guy to check/set tracking ;)
Re: track rod ends
« Reply #10 on: 19 June 2013, 23:53:37 »
Whats the point in replacing one then 100 miles later the other one goes  ??? They only cost pennies and if he gets the tracking done he will have to pay out again for tracking when the other TRE goes  :-\
chrisgixer
Re: track rod ends
« Reply #11 on: 19 June 2013, 23:56:17 »
You bought a French. You know nothing. ;D
Re: track rod ends
« Reply #12 on: 19 June 2013, 23:58:17 »
Just trying to save him money mate on tracking and for the cost of one more TRE surely worth doing the other side innit  ???
Anyway its what i would do  ::) Working on french cars is so therapeutic  >:(
« Last Edit: 20 June 2013, 00:00:48 by Emd »
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
Re: track rod ends
« Reply #13 on: 20 June 2013, 00:00:22 »
full 4 wheel geo wim you mean  ::)  :-X ..
Re: track rod ends
« Reply #14 on: 20 June 2013, 00:01:38 »
Exactly  :-X
