Author Topic: Cruising speed  (Read 2897 times)
Tony H
  • liverpool
  • Black Elites are luurvley
Cruising speed
« on: 18 May 2008, 20:51:10 »
How do everybody out there :y. I have been doing quite a few motorway runs lately, which is something I have not done a lot of in my Miggy. Can anyone tell me what the optimum fuel efficient speed to set the cruise at? I'm not concerned about speed just economy. Mines a 2.5 petrol auto.
Re: Cruising speed
« Reply #1 on: 18 May 2008, 20:53:34 »
Does yours have the fuel computer onit?
Your profile says you have an Elite, if so and it's gotthe computer then just set the display to instant MPG.
Re: Cruising speed
« Reply #2 on: 18 May 2008, 20:55:04 »
Obviously hills and weather conditions will make a difference but on my Carlton Diplomat I found the MPG varied on warmer/colder days
« Last Edit: 18 May 2008, 20:55:17 by skruntie »
Tony H
  • liverpool
Re: Cruising speed
« Reply #3 on: 18 May 2008, 21:01:24 »
Yep, I have been experimenting with different speeds but thought someone with prior knowledge may have the info
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Cruising speed
« Reply #4 on: 18 May 2008, 21:03:57 »
I find around 80 mph seems to do well on petrol :y
Debs.
Re: Cruising speed
« Reply #5 on: 18 May 2008, 21:04:18 »
I`ve found setting cruise at 65 MPH gives my 2.5 V6 the best steady-speed economy; tyres inflated to the high-end of the load/pressure range helps very much with M`Way economy too IMHO.  :y
« Last Edit: 18 May 2008, 21:05:11 by Debs. »
Re: Cruising speed
« Reply #6 on: 18 May 2008, 21:08:24 »
my 3.0, around 70-75ish, the tractor, around 80ish
HolyCount
Re: Cruising speed
« Reply #7 on: 18 May 2008, 22:36:30 »
I seem to recall -- back in the petrol shortage days --- the figure of 56mph was bandied about as being the most fuel efficient.
Generally tho -- the most wastage is in trying to get to a cruising speed to quickly and stopping / slowing a lot. Smooth acceleration and slowing will help. A little game we used to play to encourage smooth driving habits  was to place an apple on the bonnet and try to keep it there whilst in motion !!!!
Re: Cruising speed
« Reply #8 on: 18 May 2008, 22:42:41 »
About 75-80 on mine.
jereboam
  • Suffolk
    • 1999 Omega Elite 3.0
Re: Cruising speed
« Reply #9 on: 18 May 2008, 22:55:56 »
Yeah - 75-80 seems best for my 3.0 auto.  On a run I get about 32 mpg - absolutely amazing, really :).  Of course, back and forward to the shops or into town gives a figure of about 17 mpg, which is dreadful >:(
« Last Edit: 18 May 2008, 22:56:20 by plstewart »
Re: Cruising speed
« Reply #10 on: 18 May 2008, 23:01:38 »
Tow a caravan for any distance & then you'll know what crap mpg is!!  ;D Just come back from Grassington (Skipton-ish) and although I generally get around 20 mpg, while on the M65 up a long incline the instantanious consumption was hovering around single figure mpg! I was in 3rd gear too!  :-?
jereboam
  • Suffolk
Re: Cruising speed
« Reply #11 on: 18 May 2008, 23:11:25 »
If I ever express a desire to tow a caravan, my children have instructions to book me a place at the nearest euthanasia facility :(
Re: Cruising speed
« Reply #12 on: 19 May 2008, 09:51:17 »
I find, as long as you're above about 50 so the autobox stays locked up in top gear, the faster you go, the more it burns. Can achieve 36/37 MPG at a constant 65 or so. Any faster and it gets more thirsty. As said, avoid changing speeds - look ahead and plan lane changes in advance.
Makes for a very boring drive, though. Best to cane it and sod the expense. :y
Re: Cruising speed
« Reply #13 on: 19 May 2008, 09:54:27 »
At 65-70 I get upto 40ish mpg.....the difficult bit is keeping the car that slow!
Re: Cruising speed
« Reply #14 on: 19 May 2008, 10:55:12 »
In case of my tractor, anything below 70mph, I tend to keep it in 3rd to achieve best economy (and performance), hence why 70-80mph seems to be the most economical speed for that.  Below 70 in D/4th, it is outside of its power range, and seems to use more fuel.
