Electric car jack
Started by Shackeng, 20 June 2013, 09:14:17
Shackeng
Webby the Bear
i presume it has some manual stop and reverse button?  :y
RIP Paul Lovejoy
A friend of mine has one - it works alright although it's tediously slow to get anywhere (obviously it has to be massively geared down to get the torque required to lift a car).. I can't imagine replacing a good quality trolley jack with one, though.
sdwall
Surely a miggy weighs more than that can lift?
Shackeng
They go up to 2 Ton, but a 1.5 should be OK for a wheel change. It just looks handy for touring. :y
sdwall
henryd
Quote from: Shackeng on 20 June 2013, 10:50:14
I wonder if it'll lift high enough,fair bit of suspension travel on a mig before the wheel clears the ground ???
other rides
scimmy_man
how about a normal sissor jack and a cordless drill?
Shackeng
Quote from: scimmy_man on 20 June 2013, 15:31:41
Could work I suppose, but this is purpose built, and I suspect that a cordless drill would struggle to lift with a scissor jack. :-\
Shackeng
Quote from: henryd on 20 June 2013, 11:31:50
Good point, they go from 110 up to 350mm. Anyone know what we need on the fronts? :-\ I think the jacking beam is about 150 so a block of wood would help.
Rods2
Quote from: Shackeng on 20 June 2013, 09:14:17
Does anyone have any experience of these? Looks quite useful for old farts like me. :y
http://www.ebay.co.uk/itm/ELECTRIC-CAR-JACK-1-5-TON-1500kg-12VOLT-REMOTE-CONTROL-CIGARETTE-LIGHTER-POWERED-/390600947431
I read the advert that it is suitable for cars that weigh less than 1.5 tonnes. I would have thought you would want the 2 tonne model with an Omega.
omegod
Quote from: Rods2 on 20 June 2013, 19:32:59
If it's just for wheel changes it would be fine, only lifting 1/4 of 1.7 tonnes.
Rods2
Quote from: omegod on 20 June 2013, 19:54:31
From the advert:
"PLEASE BE SURE THAT THE CAR YOU INTEND TO LIFT IS LESS THAN 1500 kilograms TO AVOID OVERLOADING AND DAMAGING THE JACK."
This suggests to me that the advert is a little misleading and it cannot lift much more than 375kg or 25% of 1,500kg.
Personally, I would want to be in on a motorway or the backend of beyond, pouring with rain, with a puncture to find that this jack was not man enough to lift the car to change the wheel. If I was spending £59.99 I would spend the extra £10 for the 2 tonne.
Shackeng
Quote from: Rods2 on 20 June 2013, 20:32:56
From the advert:
Agreed, I had already decided, if I get one, to get the bigger one. :y :y :y
why not look for a scissor jack that has a 17mm hexdrive(same as the wheel nuts for convienience) and a cheap, long-handled ratchet. which would also be useful for loosening the wheelnuts.
