All set for the winter
Started by Elite Pete, 10 November 2006, 08:51:47
Well thats me done. This week I have changed the engine oil and filter, fuel filter, cabin filter and air filter. In the last couple off months I have fitted a new battery, replaced the anti freeze and had a couple of new tyres. I did want to change the gearbox and diff oil but the wifes Rover diesel exhaust started blowing this week so I thought while im replacing the exhaust I might as well add a few BHP and bought a decat pipe as well, what a difference. So thats it, me done  ;)
Bo Bo
Done all that too except for the battery which is still under warranty  ;)
theolodian
Similar here, except that air & cabin filters responded to the Henry quite well so didn't replace them.  Cleaned leaves out of scuttle.  Rotated and balanced tires.  Haven't touched wipers, battery or fuel filter.
[move]Trains may have been invented here, but public transport is a foreign concept![/move]
Chopsdad
Where are the cabin filters hidden?
QuoteWhere are the cabin filters hidden?
Engine bay, passenger side, under scuttle...
Bo Bo
& be carefull not to break the clips  :-[
PaulW
#7
Still need to sort mine... Im too lazy :(
list to do:
1) Coolant flush and change (have 5ltrs of AF waiting)
2) Oil change & filter
3) Fuel Filter
4) Air Filter / Pollent Filter
5) Sort out Air-Con
6) Actually get round to fitting the ABS unit I got from RMCB waaaaay back...
7) Investigate the wobbly vibration above 50mph when accelerating (stops when i lift off the gas) probably related to a suspect 'loose' diff which drury lane pointed out to me... is catching the OS rear abs sensor but it wobbles...
8) Buy wooly mittens and a bobble hat
Humbugs...
PaulW
#8
although I did get asked by the ex to do a coolant change on her car which I said I did but actually didnt...
i cant help it if I just dont like her or her car...  bloody clit's...
Humbugs...
MikeDundee
Err, how doy ou do that?, I normally don't bother :-[
Salty
Mine is hopefully ready. 2 new tyres, oil changed and new filter(twice) air and pollen filters, new wiper blades and new windscreen. Done the cambelt, water pump(antifreeze at same time) and rocker gaskets.
MOT next week so the list may get bigger after that :-?
Taxi_Driver
QuoteMine is hopefully ready. 2 new tyres, oil changed and new filter(twice) air and pollen filters, new wiper blades and new windscreen. Done the cambelt, water pump(antifreeze at same time) and rocker gaskets.
Mine needs a 80k service in a few k's  :(
Not sure wether to have the cambelt/etc done at the same time, it had a new water pump fitted a 50kish miles, vx dealer put a new cambelt on at the same time......but did they change the tensioners as well? dunno.....so just for piece of mind i'll more than likely get it all done.
Mine also needs new wipers......does any one know if the new 'flat' type of blade sold by vx dealers will fit an omega?
iggy21uk
Should be set for winter  now  :)
Done most of the above as its just passed the mot.
I also topped up washer ' bottle'
[color=red][size=10]Opelscanner Can owner / Cam lock kit owner [/size] [/color]
Full brake service and fluid change on the facelift today....and it was a git!
Ow look.....2000 posts!
Rock
Congrats on the 2000 posts Mark... :y
[move] Cambelt changed 03/12/06. [/move]
