Author Topic: Continued..Water pump leak, etc some more questions before I continue!  (Read 1133 times)
Paulus62
  • Llanfairfechan. North Wales
    • 2001 2.6 Estate Manual
Hi All,
I am now almost at the stage of putting things back together but I need a few points/questions clarifying before I do something wrong!
If I'm right this bolt is hollow? should I take it out and clean it to leave be?
As the oil requires changing do I empty it before starting and put fresh in once it back together, or should I put it back together and run her for a little while to warm the oil up as per oil change guide?
As the cam covers had lots of flakey dried oil all over them I would assume that some of this would have come off when running and would end up in the sump? If that is the case should I remove the sump to clean it out or would the oil change clear most of it out?
(I don't fancy doing that unless necessary - too much mess potentially ::) ) I'm worried that if there is a lot of crud in the sump some of it may end up blocking something important, or am I being too pessimistic?
Cheers,
Paul  (At least I can follow dbug's instructions :y  'on how to get Dropbox pics to load'  ;D)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
I have no idea what that hollow thing is  :-\
however, put it all back together then change your oil. i wouldn't bother cleaning sump  :y
RIP Paul Lovejoy
Webby the Bear
  • Northampton
ps that's just my opinion.... best wait for an expert to confirm whether they agree or not  :y
RIP Paul Lovejoy
Got the PM ok then Paul :y  Well done mate ;)
Paulus62
Cheers dbug  :y  seemples, when you know how  ;)
Thanks WtB   :y as no one has disagreed I'll do That.  :y
I really didn't fancy the sump ::) & the ?hollow nut must be working or there would be a oil pressure problem?  ???
